All Free 94-98 12v mods....
Old Jul 1, 2006 | 12:30 AM
12valve's Avatar
Another free mod: make the governor rack travel further!!!
A pain to get to that place at the pump!! and besides, i need to proove it more before i officialy tell everyone what i found out!!
what i can see untill now is a loooot more smoke!!!
Old Jul 1, 2006 | 12:46 AM
hotmopr's Avatar
Originally Posted by 12valve
why grind it? take it out!! and put it back in once you wanna control the smoke again!
I have heard there is a pin that can break in the pump if the rack moves to far forward. Some do, some dont..
Old Jul 1, 2006 | 12:48 AM
hotmopr's Avatar
you can also turn the full throttle screw all the way in. I havent figured out how because mine has a smooth bolt and I cant get a grip on it..
Old Jul 19, 2006 | 09:54 AM
Ramdriver15's Avatar
keep em coming this is turning out nice!!!
lol
well im back, no more restriction no more surgery and now to start working and keep tuning my machine!!!
2 blood clots one rib removed and a whole lotta pain, now im back!!!
Old Jul 20, 2006 | 12:28 AM
12valve's Avatar
here i meant the AFC rack! Not the plate! the gov arm moves untill it hits the plate though!
you can also turn the full throttle screw all the way in. I havent figured out how because mine has a smooth bolt and I cant get a grip on it....
the screw as a round head, but that same screw has a 10 mm but on in that keeps it tight!
if its a 96 and up, itll have a little plastic ring around it, break it away with putting a flat screw driver! then loosen it with a 10 mm, and turn it in with the fingers!
if its a 94 and or 95, its a lot harder, hmmm need to figure out how to explain it! i have done it so often already!
Old Jul 22, 2006 | 11:05 AM
i tried this today with the afc foot. noticed some increase in smoke but not as much as i though. My turbo spools up a heck of a lot quicker. also now in park or nuetral during a free rev i make about 10 psi of boost, before i couldnt make any! this is pretty sweet... but will this cause any problems in my pump seeing as i cant replace it....
i dont have the money right now or id have a nice new built up tranny!!
Old Jul 22, 2006 | 12:49 PM
12valve's Avatar
did ya take the "afc foot" out?
try that on a 215! hehe,
Old Jul 22, 2006 | 03:02 PM
lol that helps probly, but yah it was the foot i took out. in the afc housing, the little "foot" looking deal that moves with the diaphram and boost?
Old Aug 6, 2006 | 10:50 AM
12vstrokethis's Avatar
hey if you do the gsk shim will the 3 gsk will it make them like 4gsk
Old Aug 6, 2006 | 01:35 PM
ive never heard of anyone doing that yet... give it a try and see what you comeup with. you will need to get new valve springs though!!
Old Aug 6, 2006 | 05:30 PM
Dave88LX's Avatar
One can build boost in neutral with no load? I thought there had to be a load against the engine in order to build boost?
Old Aug 7, 2006 | 07:22 PM
i make 10 psi in neutral but it is totally pointless. With the auto you cant drop it into gear cuz itll be destroyed...lol, but yah i make 10 psi in neutral now. only since i removed that afc foot and the turbo lights at lolwer rpms....
Old Aug 7, 2006 | 08:29 PM
dslpower's Avatar
I can make 6psi in neutral w/ stock plate in stock location, afc slid forward and starwheel loose, w/cat convertor and muffler.
Does'nt do a bit of good for anything, like Ramdriver said the auto would selfdestruct if you pulled it into gear.
Old Aug 8, 2006 | 04:06 PM
My auto is already doing that with out dropping it into gear. I dk how long it is gonna last but its getting bad....i got the nastiest shudder and it kicks in as soon as i hit the throttle and reach 17-2200 rpms. Im gonna be needing a new one soon!!!
Old Aug 8, 2006 | 04:39 PM
STACKED's Avatar
You figured out how to turn up the full throttle screw on a 94-95 yet.
