All Autos......
Old Apr 15, 2008 | 12:50 PM
CODODGE2500MAN's Avatar
All Autos......
Has anyone with a 24v auto relocated the OD on/off button?
If so, what wires did you tap and where did you put it?
My switch is a pain to put on and off and I thought it might be nice to put the switch elsewhere for ease/comfort...
Old Apr 15, 2008 | 02:13 PM
Russ Roth's Avatar
I can't think of any place that seems more convenient to me than right where it is. I have thought about swapping it with my lock up switch because I use that more often and it is not as convenient. I haven't got far enough to actually look into the wires to grab though.
Old Apr 15, 2008 | 02:17 PM
Eventually I'd like to have both the OD switch and the exhaust brake switch next to each other ( on my cup smoothie / where my hand always rests while I'm driving.
Anyone done it?
Old Apr 15, 2008 | 03:23 PM
JIT's Avatar
JIT
Anyone done it?
Mounting a switch in a cup shouldnt be too hard. Are you going to use plastic or Styrofoam? I think it would look sweet in one of those Large Sweet Tea Cups from Mcdonalds.
Old Apr 15, 2008 | 03:45 PM
First, Its a cup smoothie from Geno's
Second, lets just say if you are going to add to the question, save it!!!
Old Apr 15, 2008 | 03:54 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I also feel it's pretty good right where it's at now. All's I gotta do is raise my hand a bit and push. Simple. I'm not sure which wires you gotta splice into. But pull off the column cover and take a look see. It's real easy. There are 3 torx tipped screws on the bottem of the cover.
Old Apr 15, 2008 | 07:39 PM
I'll take the cover off tonight and look to see what I have.....
What wires are tapped for a smoke switch, or is that totally different?
Old Apr 15, 2008 | 07:46 PM
JPR Ram's Avatar
Different wires. For a smoke switch or a mystery switch or more accurately a torque converter lock switch, you need to tap the orange wire with blk tracer down by the ECM. Then run a wire from the tap into the cab to a 33 ohm resister, then to the switch. The other side of the switch attach another wire and ground that. With some trucks you also need to pull out the tranny relay and jump two connections. I didn't, and mine works just fine.
Old Apr 15, 2008 | 07:48 PM
JPR Ram's Avatar
Oh, BTW....NICE YJ.
Old Apr 15, 2008 | 08:06 PM
Thank you very much....its a little different now....black with a blue roll cage, tube fenders, and some other toys....pretty much a trail only rig now....Kinda wish I could drive it again on nice days!
Old Apr 15, 2008 | 08:07 PM
Any adverse affects...?
I'm getting a dtt single disk put in currently.....
Old Apr 15, 2008 | 09:35 PM
JPR Ram's Avatar
I haven't found any yet........... Just be sure not to forget to disengage the switch when coming to a stop.
CTDowerTN
Nov 21, 2006 08:36 AM
Officer Al
Nov 13, 2004 04:32 PM
LanceD
Oct 15, 2004 01:12 PM
crankbait
Jan 16, 2004 12:25 PM
st_pinetree
Apr 13, 2003 07:59 AM
