air horns yesterday today no compressor
air hons on yesterday and today the pump blew out on me. just curious about what to do. it is supposed to be warranteed and im gonna pursue that. Im curious if there is a way convert my a/c compressor into an air compressor. And how hard/ much $$$ will it cost. thanks
My little bronco II has onboard air using an AC compressor. Ive had it on since about july and its worked great for me. Pretty simple to do, took me about 4 hours to get it done, I could do it much faster a second time if I had too. I oil it every once in a while, I also have a filter on the intake.
Did your compressor motor give up or is it no longer pumping up the system?
Mine ran forever one day and never brought the pressure up.
I pulled the pump, refilled the oil reservoir and it's been good to go since.
take a look at http://www.kilbyenterprises.com/bracket-kits.htm it puts a york a/c compressor under the hood of your truck right nexted to the alt. with prices for the brackets about $172. I think it's a heck of a deal and you still have A/c of the truck some thing I not willing to go with out.
great idea... this bearing is a 626z and i found a 696z but it was like one mm too big...
but if i use my patience then im going to go to South Shore Bearing for the new bearing and have tem press it on and do the whole deal... They are a local shop that carries every type of bearing...
francis
Feb 25, 2008 07:47 AM
Asher
Oct 27, 2007 09:50 AM
Ramdriver15
Oct 2, 2006 06:28 PM
carcrz
Sep 17, 2006 02:22 PM
