Hadley Air Horns - need compressor/tank
Old Mar 25, 2004 | 10:53 AM
dupp's Avatar
Have a nice set of Hadley Air Horns on my '91 D-250, but they came without a compressor and a rotten air tank under the hood.
Any good ideas/recommnendations on cost/where to purchase a decent air compressor and air tank to run these monsters?
Appreciate it,
Mike
Old Mar 25, 2004 | 04:44 PM
RedWhiteDiesel's Avatar
I would suggest going to a junkyard and seeing if you can find an old shock air compressor out of a car. I snatched mine out of a car from the shop just before it went on the flatbed. As for a tank, my tank is simply made from an old Freon tank. I took the plastic valve out of the top, welded a bolt on where the valve was, and put a piece of steel line on the output end with a compression fitting on the end. I attached the tank with some steel strapping underneath the bed of the truck, on the drivers side, near the front. Good luck!
Brian
francis
Feb 25, 2008 07:47 AM
Asher
Oct 27, 2007 09:50 AM
Ramdriver15
Sep 17, 2006 06:44 PM
carcrz
Sep 17, 2006 02:22 PM
mikeg135
Jul 20, 2006 05:45 AM
