air filter
Old Dec 7, 2003 | 11:15 PM
ROTTBERG's Avatar
Re:air filter
speaking of air filters, i ordered my Scotty II over a month ago and still nothing. anyone else have to wait on their box ?
Old Dec 7, 2003 | 11:27 PM
Scotty's Avatar
Top's Younger Twin
Re:air filter
I sent you a private message...please respond so I can get this resolved.
Scotty
I am beginning to think that there are several customs folks at the border that own Dodges.
Old Dec 8, 2003 | 10:16 AM
Olratlr's Avatar
Re:air filter
ScottyII With hole you will Love it. ;D
Old Dec 8, 2003 | 01:02 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:air filter
[quote author=Scotty link=board=7;threadid=23261;start=15#msg219967 date=1070861264]I am beginning to think that there are several customs folks at the border that own Dodges.
[/quote]
perhaps you should print on the box in large lettering
"Will NOT Fit on Cummins 5.9 installed in UPS trucks."
Old Dec 17, 2003 | 06:50 PM
bama's Avatar
Re:air filter
ive been doing some testing with a flowmeter lately and so far the results have been pretty interesting.theres alot of opinions on filter set ups but nobody seems to have numbers to back them up.the stock box with drop in filters flows around 550cfm.the popular bhaf flows around 700cfm.a k&n 9 inch open flows around 750cfm.the best flowing so far has been the afe megacannon at 1050cfm.i havent laid hands on a scotty yet.with the inlet boot open,pulling raw air with no filter on my truck it pulled 400cfm at idle,1375cfm at 2500,and 1550cfm at 3000rpm.this is a hy35 with wastegate.with any of the other turbo,s,it would only be more. i hope this helps you.
Old Dec 17, 2003 | 08:43 PM
jigdog's Avatar
Re:air filter
Dan: I had 8 2 inch holes in my stock air box with a drop in kn and it made a 2 mpg difference but alot of noise (to me and Mama) so i plugged them and am thinking of how to do it different and no noise or less noise and block the heat from the eng. :
Old Dec 18, 2003 | 05:58 AM
rattle_rattle's Avatar
Re:air filter
[quote author=bama link=board=7;threadid=23261;start=15#msg225413 date=1071708618]
[/quote]
Great data! What does your test setup look like?
Old Dec 18, 2003 | 07:09 AM
Tartarus's Avatar
Re:air filter
Hey, Scotty -- you and Rod fooled around with the AFE Proguard 7 yet? I'm getting much better dust filtration results with that filter, but I have no idea how the design cuts down on flow. Doesn't seem to, seat-of-the-pants.
Old Dec 18, 2003 | 07:33 PM
bama's Avatar
Re:air filter
rattlerattle my testing was done with a $1500.00 handheld flowmeter we use in hvac work.it has a long lead and probe similar to a multimeter.i slipped the probe through the filter element to get my readings.im still trying to get my hands on a scotty system to test.it is supposed to be close to the megacannon on cfm but be better on air temp.my meter also has air temp. capabilities.the supposed relation is 1 degree higher intake temp results in 3 degrees of exhaust gas temp. if this turns out true,the scotty could be the way to go,especially for hy owners.
Old Dec 19, 2003 | 04:18 AM
P.O.R.'s Avatar
Re:air filter
I'am running SCOTTYII with the hole,only took 5 days to recieve. ;D
Old Dec 19, 2003 | 04:56 PM
smokeblower's Avatar
Re:air filter
Using a drop-in k&n for now, saving money for a clutch so haven'nt went with an entire intake setup
Interesting reading! Those who havent read it anyway.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
EverydayDiesel
22
Jun 3, 2010 12:10 AM
Wildhog
13
Aug 4, 2008 08:07 PM
herb
Jul 18, 2008 08:25 AM
nfsommer
Apr 16, 2007 09:21 PM
royta
Sep 17, 2005 10:25 PM
