Adding factory fogs to 02 Ram
Old Dec 31, 2011 | 02:39 PM
Josh1979's Avatar
I've grown tired of not be able to see well in bad weather. My 02 doesn't have fog lights, just the empty holes in the bumper. I see my truck has the little blue plug behind the bumper where the lights plug into.
I've found that Rockauto.com sells everything I need to add them at a decent price. For around $150 - 160.
I need to a list from you guys that have done this. What else do I need?
  1. L & R bumper inserts
  2. Fog lights
  3. Correct headlight switch
  4. Fog Light relay
I think I need the wiring that ties the lights together and plugs into the blue plug. But I don't see it on rock auto's website.
If someone could send me in the right direction, I'd sure appreciate it.
Old Dec 31, 2011 | 07:15 PM
Silver R/T's Avatar
can you post a pic of what plug looks like
Old Jan 5, 2012 | 05:11 PM
SIXSLUG's Avatar
IIRC the guts in the fuse box behind the battery won't contain the needed connectors for the fuse and relays to plug into.
We ran an aftermarket switch, relay and trip wire to Dad's 94.
An old school floor mounted high beam switch is a good HD switch and easy to trigger without cutting holes in the dash.
Old Jan 6, 2012 | 02:41 PM
Josh1979's Avatar
Thanks for the info guys. But I found the Mopar OEM kit on ebay for $170.00.
Old Jan 6, 2012 | 04:35 PM
SIXSLUG's Avatar
Josh, the schematics in the Factory service manual would be very helpful if you are trying to go all stock on this., if you can find access to one.
K
Old Jan 7, 2012 | 01:48 PM
Josh1979's Avatar
K
The 98.5-02 trucks with the cargo light are all pre-wired from the bumper to the dash. It's a matter of bolting in the lights and changing the switch. The fog light relay is already in the power center too.
grapplerusa
Sep 15, 2011 09:18 PM
lowboy18011
Apr 15, 2008 08:49 AM
CNYRAM
23
Apr 20, 2004 07:09 PM
RamDan03
20
Oct 6, 2003 02:39 PM
FastSS
Feb 7, 2003 06:18 PM
