Added CFM+ & Heater Deleter= Less Boost???
I just added the CFM+ intake and Winspeed Heater Grid Delete spacer and lost about 3psi peak Boost? Is this because there is less restriction in flow meaning lower drive pressures? I checked for boost leaks and didnt find anything unusual. Is this normal?
The problem is the boost pressure is measured down stream of the air horn and grid heater. So the loss of up stream restriction should mean more boost pressure at the manifold (where the boost is measured).
A really good test for those that are so inclined would be to install a second boost gauge at the outlet of the inner cooler. There they will see a major drop in boost pressure with a heater delete.
Thats what I am thinking. Throttle response has increased and the turbo is really singing now. I'm happy with the components I just didnt know where the other 3psi went? Where does the stock system Map sensor measure boost Pressure?
The same thing happened to me when I installed the banks twin ram (should have gone with something else but I got it cheep) on my 12 valve i lost 4 psi with my stock charger but my egt's droped and my mpg's went up a little and the turbo really does sing now
I agree with the explanation for the loss of boost. It is related to restriction. If you installed a cam, you would also see a loss of boost because the intake valves would open longer and flow more air and exhibit less restriction.
Ronnie
Ronnie
jmccart
Jul 17, 2008 10:05 AM
js091899
Mar 16, 2008 07:28 PM
RonP
Apr 2, 2007 12:25 PM
