???? about 370 injectors
dodgeman01,
adjusted my springs again today to see what would happen. I backed them off one click and so far the bucking has gone away. It used to buck really bad when it was cold but it has not done it yet. Every click should net you about .017 of an inch so mine should be right around .033. Like I said before I could not get the 4K's right. You may want to try taking the smallest spring out of the 4K kit. That will turn it into a 3K kit. I have been told by several people that the 4K kit is a bit touchier than the 3K. I am going to adjust a couple more things this weekend. I will let you know what I found. BTW have you checked your throttle return spring. Mine was getting a bit weak and causing the throttle to bounce. PM me if you like. Good Luck
Justin
Justin
Originally posted by dodgeman01
Vin you truck is an auto so I don't think you would feel the lope that we feel. The engine seems to run smooth but when pulling a trailer it really don't like it unless I'm at WOT the whole time.
DM01
DM01
Originally posted by yrusoslow2
dodgeman01,
Justin
dodgeman01,
Justin
thanks
DM01
Aug 25, 2003 10:49 AM
JCamper
May 15, 2003 09:30 PM
