600 on #2
Old Oct 25, 2005 | 09:47 PM
lco's Avatar
lco
600 on #2
is 600whp on #2 with a single turbo possible, what would be a combo for this?
Old Oct 26, 2005 | 07:41 AM
turbo thom's Avatar
How are you going to get 600 on a single, then want to combo?
Old Oct 26, 2005 | 07:44 AM
gunracer1's Avatar
it would be a lag pig on the bottom really not that hard to do, it has been done more than a few times.
Old Oct 26, 2005 | 09:02 AM
getblown5.9's Avatar
i would venture to say something like
sledpuller 66 or bigger turbo
mach 6's or maybe even bigger
edge drag comp and MAD ecm with no timing
OR TST PM3 Competition version fueling box stacked with a timing box like VA
gonna need head studs and maybe o-rings on the head
serious tranny/clutch to hold it
good intake/filter
5"exhaust
i know the combo above willo give well over 500...but it may be pushing it to get 600...add some serious money in there for head porting & polishing, and a cam and you got your 600 for sure.
Old Oct 26, 2005 | 09:22 AM
RowJ's Avatar
Can be done.
The list above would work...but I would replace the turbo with a Full B-1 or an HX-55/16 from JR Adkins.
I would not do it on an automatic and expect to drive it every day on the street.
For expert advise from someone who has done it - talk to Olie Poole...
http://www.powerbypoole.com/dtt.html
RJ
Old Oct 26, 2005 | 10:10 AM
ctd89-99's Avatar
600 on #2
At the MASON DIXON TURBO DIESEL CLUB FALL BRAWL in Dillsburg Pa. at KAUFFMANS MOTOR SPORTS there was a 98.5 single charger truck that did 605. Thanks Steve B.
Old Oct 26, 2005 | 11:13 AM
lco's Avatar
lco
12 valve, sorry.
Old Oct 26, 2005 | 11:20 AM
RowJ's Avatar
Ico, Fill in your signature...under User CP...so we all know what you have.
RJ
Old Oct 26, 2005 | 11:26 AM
lco's Avatar
lco
which b1 from piers
B-1 Bomber Series Turbos
PDRB-1 B-1 Bomber - Mid to High HP w/manual trans. $1600.00
PDRB-1-2 B-1-2 Mid to High HP faster spool up than B-1 $1600.00
PDRB-1-EX3 B-1-EX3 - Same as B-1 with HX35 outlet $1600.00
PDRB-1-EX-4 B-1-EX4 - Same as B-1 with HX40outlet $1650.00
PDRKSB-1 KSB-1 Bomber - Mid to High HP w/faster spool up than the B-1-2 $1600.00
PDRKSB-1-2 KSB-1-2 - Very fast spool up. High Altitude, Automatic Transmission $1600.00
PDRKSB-1-EX4 KSB-1-EX4 - Same as KSB-1 with HX40 outlet
$1650.00
KSB-1-2-EX4 - Same as KSB-1-2 with HX40 outlet $1650.00
Steriod B-1 - High Performance - Not recommended for Daily Driving - special order only $1800.00
B-1 Downpipe - Regular outlet only $150.00
V-band clamp for B1 turbo $34.00
Old Oct 26, 2005 | 11:37 AM
RowJ's Avatar
B-1 Bomber...w/ B-1 down pipe!
RJ
Old Oct 26, 2005 | 11:44 AM
Jetpilot's Avatar
It can be done and be streetable here is what will work....
A good motor and injection pump
Either a Steroid B-1 or a SPS66 turbo
Formula 1 mach 6 injectors
Edge drag comp or a Redline box
AFE mega-cannon filter
This combo will work well with an auto tranny. The standard B-1 or an HX55 will not supply enough air to reach the 600 RWHP mark.
Doug
Old Oct 26, 2005 | 11:57 AM
blackdiesel's Avatar
Registered
Doug
He said it was a 12v
Old Oct 26, 2005 | 12:09 PM
lco's Avatar
lco
thanks for tying to help me tho, atleast i got some response lol. but thanks for your replys on the turbo question, seems like every where else i ask they think i'm crazy for trying to use a single charger and they all just say to go twins. i just can't see myself spending 4 times the cost of a single to get twins just to get rid of a little lag. i would spray a little 50 shot of nitrous to spool before i went twins i think.
Old Oct 26, 2005 | 12:13 PM
TxDiesel007's Avatar
Ok this would be my stab
at 600 RWHP.. with a 12 V
370 injectors,
0 or 100 plate
Timing at 17 or higher
Headwork
BIIIGG turbo B2 or steroid B1
BHAF or scotty II
4K GSK
Exhaust
Delivery Valves.
Cam
Pistons
Marine Gaskets
Tranny work (mandatory)
BEST gauges you can afford...
or the easy way
PDR 370s
PDR Twins
PDR Stoopid pump
or PDR steroid Bomber...
Welcome to DTR.. Please filll in your sig so we can better assist you... Your goal can be reached, with lotsa time, patience and money. Best of luck!
Tx
Old Oct 26, 2005 | 12:16 PM
That will heat up your EGTS even quicker
The reason twins are reccomended is not just for power, but the further compressed air you get out of twins will also drop your EGTS.. Water or Methanol injection is also beneficial and wont be as bad on your EGTS.
I want 500 RWHP and Daily Drivability, but i want cooler EGTS and a not so lag pig truck.. SO twins would probably be my best bet.....
Tx
