5spd ?
Old Oct 27, 2004 | 11:59 PM
SmokinFive9 4x4's Avatar
5spd ?
Did they put the NV4500's in the gas trucks too? V-10's maybe or 360's? if so, is it just as strong as from a diesel? My dad has a 98 Ram2500 4x4, 360, 5spd. I wonder,,,would he notice if it were automatic one day?
Old Oct 28, 2004 | 12:07 AM
Now that I think about it, the gear ratios are probably different aren't they? Not too suited for the CTD's
Old Oct 28, 2004 | 12:44 AM
Dr. Evil's Avatar
My girlfriend had a NV4500 HD in a 2 wd half ton (V6)....
Old Oct 28, 2004 | 06:00 AM
DZLPWR's Avatar
Here's some info http://www.dodgeram.org/tech/transmi...v4500_spec.htm
Old Oct 28, 2004 | 10:27 AM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
some of the early gasser 360 ones had a 23s pline output shaft (weak) and 1 1/8 input (same as the chevy's). The V-10 models though are the same as the cummins and i believe the 99 and later gasser 360 nv4500's use the same output as the v-10's and diesels at that point.
They all have the same gear ratios in NV4500's, the only exception are the 92-94 chevy models that came with a 6.34:1 1st gear and 1st and reverse are not syncronized. the Dodge version is the same in diesels and V-10s from 94-when they did away with em recently. all have a 5.63:1 first gear ratio there are no other gear sets that were used by dodge.
Old Oct 28, 2004 | 12:05 PM
Ok, so what about the bellhousing? What bolt pattern does a cummins engine use? Is it the same as the 360 or V-10. My whole idea behind this is that it's gotta be alot easier to find a wrecked gasser for cheap that I could steal one out of. And don't you have to change the input shafts on the nv4500's anyways, or at least it's recommended to go with the 13" clutch?
Old Oct 28, 2004 | 12:13 PM
ddestruel's Avatar
I paid $200 for the bell housing, flywheel and bolts for a cummins and nv4500 from spalding wrecking yard in spokane washington. I dont believe the 360 bellhousing will work it is shorter because of the shorter & smaller input. I have no idea on the V-10 though i have heard the V-10 and cummins share the same bell pattern, somewhere i thought i read that guys were yanking 2wd cummins automatics and putting them into the vipers.
R-O-B
13
Mar 16, 2003 11:59 PM
AFMSgt
Jan 26, 2003 08:27 PM
Sarge1124
24
Dec 7, 2002 07:23 AM
dodgeman01
Nov 18, 2002 07:47 AM
dodgeman01
Oct 29, 2002 12:47 PM
