2wd 5spd into a 4wd that has a 5spd????
Old Mar 15, 2003 | 04:00 PM
R-O-B's Avatar
Before everyone says sell it and get a 2wd. I want to know how hard it would be to replace the transmission and transfer case with a 2wd unit? My transfer case crapped today and I never use 4wd, so I figured it might be a cheaper fix and would eliminate the possibility of the same thing happining again. Thanks in advance...
Old Mar 15, 2003 | 05:55 PM
DuallyJeff's Avatar
Re:2wd 5spd into a 4wd that has a 5spd????
I wish to god that I had 4wd sometimes. I have no idea why you would want to not repair and keep it.
Old Mar 15, 2003 | 10:28 PM
R-O-B's Avatar
I run a delivery service and the thought of repairing another transfer case makes me cringe. 99% of my driving is on paved streets, the other 1% are om graded roads. I've used the 4wd 4 times in the 6 months and three times were to get motorhomes with trailers unstuck.
Old Mar 16, 2003 | 12:04 AM
P Kennedy's Avatar
ROB something here is not right, I am assuming by being on the 1st Gen forum your truck is 93 and older. This would mean you have a NP205 T-case which is gear driven and one of the most wanted parts in the continent. What reasons are they failing, you realize the value of the truck will decrease by 40-50% by making it a freak. PK
Old Mar 16, 2003 | 10:56 AM
R-O-B's Avatar
Sorry, it's a 97. I thought a 12 valve engine was 94-98?? I know the 1st gen engine had 12 valves but they were concidered a 1st gen??
I don't want to get rid of the 4wd parts but I don't need them right now and at $1200 for a reman t-case I was thinking a 2wd tranny swap might be more cost effective in the long run, no t-case to go bad again. I was hoping all I would need is the trans and a driveline, but I'm don't know.
Old Mar 16, 2003 | 07:46 PM
mymaur's Avatar
ROB<br><br>So far seems like no one has given you an answer, just a ration of grief. I don't have the answer for you but I know a guy that does. He is on this FORUM and his handle is TBGH.<br><br>I'll email him tonight and ask him to contact you.<br><br>Gary
Old Mar 16, 2003 | 08:11 PM
R-O-B's Avatar
Thanks!!!
Old Mar 16, 2003 | 10:22 PM
P Kennedy's Avatar
Wasn't trying to give anybody grief just could not see the economy in removing one of the most reliable trouble free components of the truck. Start swapping things around and the possibilty to create more un-needed headaches will arise. If you want what it takes- Driveline-lengthened,output yoke maybe different, crossmember moved/replaced, and rear angle of diff may have to be changed to prevent vibration. #1 verify that you have a NP205 transfer case- #2 $1200 US is criminal for a rebuild exchange #3 rebuild it on kitchen table for $300 bucks unless you trashed the gears. These things were used in Dodge Chev Ford, if the case is okay rob the guts out of a used one $150-300. The hardest part of working on a 205 is getting all the needle bearings in place as they are not caged. PK
Old Mar 16, 2003 | 10:44 PM
R-O-B's Avatar
The model # on the tag is 241 DLD. If there are that many things that might need to be canged I think I'll have the t-case fix or replaced with a used one. I though $1200 was high. Thank you very much.
Old Mar 16, 2003 | 10:58 PM
R-O-B's Avatar
I guess I should have searched for prices earlier. I can get a NEW case for $900.
Old Mar 16, 2003 | 11:03 PM
P Kennedy's Avatar
ROB starting to make more sense now the 94 and newer truck uses the 241 but were updated to 241HD for the higher HP/TQ 98 and newer. Call Advance Adapters in California they will know exactly what updates/when and what and have an exchange/update program- refill T-case with Synthetic ATF for extended high heat and milage service. You and a buddy can put this in 1 afternoon easy. IF your really hard on T-cases get an Atlas but should not be necessary. Sorry I missed the 97 in your last post. These T-cases are chain driven and need a little more TLC than a 205. PK
Old Mar 16, 2003 | 11:56 PM
R-O-B's Avatar
Thanks for the info. I'll order one tomorrow. I didn't think it was difficult to replace but I wasn't 100%. I should be able to fix no problem.
Old Mar 16, 2003 | 11:57 PM
DuallyJeff's Avatar
Yeah I would like to say I'm sorry too. I guess I just have 4X4 envy. And I don't have an answer for you either.
Old Mar 16, 2003 | 11:59 PM
R-O-B's Avatar
You don't want a 4wd, there such a pain in the a$$ to get in and out. It is great having it when it is needed.
93Fury
Mar 31, 2010 01:33 PM
Jordan5687
Feb 18, 2009 02:48 PM
wcbcruzer
Sep 5, 2008 08:36 AM
Valv
Jun 27, 2007 08:42 PM
1320
May 6, 2003 06:30 PM
