45 Psi
Old Apr 2, 2007 | 08:44 PM
CTD01's Avatar
45 Psi
I put a ball valve in between my elbow and wastegate, it make 45 psi almost closed. The truck pulls like crazy. Is this a safe boost number with no head mods? Thanx,
Paul
Old Apr 2, 2007 | 08:51 PM
mysterync's Avatar
Yes and no! Your in the danger zone! Some Folks last forever there and some 3 days! If your running high egts or timing the HG wont last long!
Last edited by mysterync; Apr 2, 2007 at 08:51 PM. Reason: Guess i should read the whole post! :D
getblown5.9's Avatar
maybe...maybe not...
its a crap shoot with these trucks...some last at 50+, some blow the first time it hits 40...
all depends on how flat the head was, and how good the head bolts were torqued when it was built.
id keep it around 40psi, unless you have about $1500 laying around for emergency o-ring, gasket, stud, head rebuilding job!!
Old Apr 2, 2007 | 08:55 PM
97DodgeRam's Avatar
Usually, head gaskets are safe up to 50 psi, depending on how high of timing you have. You're close to the danger zone. I would try to keep it as close to 45 if not a little under. If you're EGT temps are good at 40, I wouldn't worry about the 5 extra psi.
CTD01's Avatar
Studs
Well Should I just stud it or get it all done up? 40 is safe?
Old Apr 2, 2007 | 08:56 PM
mysterync's Avatar
If your going to take it down, Go all the way unless money is an issue! I would Consider doing rings and Studs! If your going for a temp. Fix just use studs!
38 Cigarette
16
Aug 28, 2015 11:27 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
ckennedy
Sep 29, 2004 05:06 PM
