4 gauges baby!!!
Old Oct 28, 2004 | 01:13 PM
cumminsboy's Avatar
4 gauges baby!!!
Well, after a long wait, I finally got my truck in the shop to get my gauges installed. I'm pumped!! What was yalls first reaction when you got in your truck after gettin gauges put in? I'm got Isspro's EV's in the white face(marine) version(EGT,Boost,FP, and Oil Pressure). Give me some feedback on what to expect. Git-R-Dun!!! cumminsboy
Old Oct 28, 2004 | 01:41 PM
BigBlue's Avatar
Egt should be around 800 or so cruising at 70 and somewhere around 1100-1200 at WOT if the probe is pre turbo (which it should be). Boost should be around 20 psi. Fp will hopefully be around 15 at idle. If it's not, then make sure it's above 8 at WOT. And oil pressure should be close to what the stock gauge is reading. It was pretty exciting to get them all hooked up and drive it for the first time. I'm on my 3rd set of gauges (Autometer, then Dakota Digital, and now ISSPRO) now. I got bored.
Old Oct 28, 2004 | 03:26 PM
RowJ's Avatar
".....Feedback on what to expect."
Keep your eye on the road...they are fun to look at!
Also, if on an A-Pillar...be aware of a slight blind spot...depending on how far back you have your seat. Easy to deal with..once your aware of it.
Good luck
RJ
Old Oct 28, 2004 | 07:30 PM
cumminsboy's Avatar
Got my truck and these gauges ROCK!!! The only thing I see wrong(maybe) is that my fuel pressure will go from around 12psi cruising to 4 or 5 automatically, is this normal or what is wrong, air in system, lift pump(I don't know).Feedback PLEASE!!! Thanks, cumminsboy
Old Oct 29, 2004 | 12:58 AM
BigBlue's Avatar
Check the connections and make sure they are solid. If that doesn't help, it's time for a new pump.
Old Oct 29, 2004 | 10:00 AM
RowJ's Avatar
Need a Lift Pump?
Check Classified Section....2 used recently listed...good price!
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
JKM
Jun 9, 2005 09:00 PM
UTAH
19
Oct 27, 2002 09:12 PM
