4" exhaust after exhaust brake?
Old Aug 25, 2004 | 08:58 PM
DPG's Avatar
DPG
I have a PacBrake exhaust brake with a stock exhaust on my truck (see sig) Will I see any EGT gains (decreases) if I mount a 4-inch exhaust after the exhaust brake? I can't afford to replace the brake, but I would like lower my EGT's some. As you can see in my sig, I use a BHAF and I don't want a Scotty II as I won't cut the hole. (Sorry, Scotty!)
DeWain
Old Aug 25, 2004 | 09:58 PM
DieselDaze's Avatar
DeWain, I have the same issue.
I have an exhaust brake as well.
I'll be interested in seeing everyones reply.
Rich
Old Aug 26, 2004 | 08:46 AM
CTD NUT's Avatar
You will see lower EGT's with 4" exhaust after the brake. It is not that much different from not having the brake. The elbow on the turbo outlets are quite similar with the brake or not.
About a year ago I helped a friend install an MBRP system on his 97 CTD tow truck and he had the factory jake on it. And sure enough he dropped an average 150* EGT - not bad for a truck that is 10,700 lbs without a load.
Old Aug 26, 2004 | 10:49 AM
Mark Craig's Avatar
Pac and EGT drop
DPG,
Yes you will see an EGT drop, we sell systems all the time to folks with Pac's BD's and even US Gears and they always get at least 90+% of the same drop as a non braked Cummins. Call us if you have any questions etc.
Mark @ DPPI
dzl_damon
Oct 26, 2009 11:00 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
Hemlockusa
Jan 28, 2006 07:07 AM
Badd Dogg Guy19
14
Apr 14, 2005 09:04 PM
