4" exhaust
Old Sep 27, 2004 | 06:14 PM
Dieselcamper's Avatar
4" exhaust
I have a 2001 HO ,6 speed that I tow a 6,000 lbs. trailer with.
I already have EGT / Boost gauges installed. The only mods. I
plan to do are Edge EZ and BHAF. Do I really need the 4"
exhaust or can I get by with a straight pipe or straight-thru
muffler. Thanks for the help.
Old Sep 28, 2004 | 08:42 AM
RowJ's Avatar
I would hold off on the 4". Probable be ok...and you have the gauges to tell you where you stand, Can always be done later if towing gets a little hot! Straight pipe is usually done for sound...don't know (have not heard it mentioned) that it will do anything for EGT's?
RJ
Old Sep 28, 2004 | 12:31 PM
bluebull's Avatar
With just an EZ upgrade you should be o.k. with stock or for a mild decrease approximatly 100 degree drop in EGT's a straight through pipe, but beware if you tow the noise can and does get annoying in my opinion. You could always get a straight through muffler from www.summitracing.com or jegs or many other places.
roughstock
Nov 2, 2013 01:48 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
Hemlockusa
Jan 28, 2006 07:07 AM
