3k Gov spring idle rebound
Old Dec 8, 2004 | 01:46 PM
wolf359's Avatar
Originally posted by dodgeman01
Actually two have said to loosen them up. call Piers he will tell you the same thing the two of us told you.
DM01
Piers agreed they were too loose. He called it govorner rebound, and to tighten it one turn.
Thanks for everyone's help. I'll try and get it adjusted by the weekend and report back.
Tim
Old Dec 9, 2004 | 10:19 AM
convertiyota's Avatar
Tim,
My idle was also low when I finished the installation. I went back in and tightened them up a click or two (can't remember now) and it idled perfectly after that.
Sean
Old Dec 10, 2004 | 02:53 PM
P.O.R.'s Avatar
i have the 3GSK and pull 10-14,000 lb.s,i don't have any complaints at all,they are awesome,i would put them in.
Old Dec 13, 2004 | 10:28 AM
wolf359's Avatar
I had it adjusted yesterday... no fix on the problem.
One turn tighter (on both).... did the same thing at a slightly higher idle
2 turns tighter (on both).... same thing, slighter higher idle still
1 turn looser (on both, than original).. same thing at lower idle.
So, we have adjusted it on either side of how it was originally aligned with no effect. It still rebounds at idle.
We called another mechanic, who thinks it might be a sticking plunger in the pump that showed up when we did the gov springs?
Anyone have any other ideas?
Thanks
Tin
Old Dec 13, 2004 | 03:56 PM
P.O.R.'s Avatar
my truck does the rebound thing to but only when the engine is cold and the colder it is outside the worse it is, but once warmed up everying is good.........
tauberson
Jan 31, 2009 11:22 PM
fishin fever
Mar 13, 2006 06:46 PM
Monty
Jul 2, 2003 02:26 PM
NeedMoPower
Feb 17, 2003 01:00 AM
boehunter49
39
Jan 12, 2003 06:19 PM
