350 cummins semi turbo on a 5.9
Old Mar 2, 2004 | 10:48 PM
Captain Insane-O's Avatar
Talking 350 cummins semi turbo on a 5.9
Just wonderin if a 350 cummins turbo would work on are 5.9s I know there is alot of mods to get all the hardware to work. I have the turbo sittin in the shop just curious. I figure it would never get spooled up and if it did you would have huge amount of fuel running through the motor and it would be one smokey hog. Would love to see it around town . Has anyone ever tried this?
Old Mar 3, 2004 | 09:59 AM
Russell's Avatar
People put bigger turbos on the 5.9 all the time, the most common is probably the hx40 off of the 8.3's. SOme people run hx50's and 55's, the 50 is off of an m11 cummins. It looks like you have plenty of mods in your sig so give it a try.
Old Mar 3, 2004 | 12:34 PM
chevy43's Avatar
It works fine as long as you use it as a twin turbo set up with the small turbo . If used by itself it would hardley work at all.
Do a search with the word twin* and you can read all about it.
Old Mar 3, 2004 | 03:18 PM
Thanks for info I figured a twin setup would work probably prtty good.
Old Mar 3, 2004 | 04:08 PM
SmokinDodge12V's Avatar
Captain can you post a pic of the turbo and set something beside of it just to see how big it is? Thanks.
Old Mar 3, 2004 | 05:19 PM
Borush's Avatar
HT3B's are common on Big Cam 350's, and HT4B's on 400 and 444's. Do you know what engine model it came from?
Boyd.
Old Mar 3, 2004 | 06:06 PM
It came off of like a 350, 77 cummins semi truck model #of turbo is vt-60 or 50 and asemmbly# is AR-12-600 the exhaust housing is the size of a b-1 comressor housing and the compressor housing is like the size of 3 b-1 compressor housings very wide too it has a 5in exhaust outlet.
Old Mar 3, 2004 | 06:59 PM
Borush's Avatar
VT-50 or ST-50 would be correct for that vintage S/C or B/C 1 NTC-350. Those are gonna be big and slow and are probably not worth your time. They were the latest and greatest way back then, but not these days. They usually get upgraded to an HT3B when its turbo time, even on an old Small Cam engine.
Boyd.
Old Mar 3, 2004 | 11:06 PM
It was on a small cam cummins and it is a VT model. I figured it would be slow and its definatly big. When it finally got spooled probably provide some great top end power.
dodgetrucker75
Cummins Conversions
Jan 11, 2010 02:46 PM
dieselfuelonly
Apr 25, 2009 01:39 PM
twistingawrench
Nov 3, 2006 04:27 PM
fschiola
Jan 8, 2005 04:04 PM
Sittenbull2
Oct 7, 2004 10:50 AM
