1999 dodge ram 2500 better mpg
Old Nov 22, 2014 | 11:13 AM
banditman's Avatar
I have a 1999 dodge ram 2500 cummins short bed with a 5 speed manual 4x4 with 89000 miles on it and was wondering how i could get better mpg? Is there any chips, intakes, exhausts, synthetic oils or other tricks to get the truck a couple more mpgs? Im getting about 18 now and would like to try to get it up to 20.
Old Nov 22, 2014 | 12:45 PM
cougar's Avatar
I would start with synthetic oil all the way around. Then look at your tires, rolling resistance is a big chunk. Brakes dragging? Change your driving habits maybe even changing your routs. Some programmers claim to improve fuel mileage, but the tendency to play defeats an gain.
Old Nov 24, 2014 | 12:36 AM
hallio217's Avatar
I average 20 mpg, but that includes alot of hauling: http://www.fuelly.com/car/dodge/ram_...eguides/259273
The highest I have got is 27.7mpg (calculated by pump, not computer). Cruise control at 55 for 70 miles of freeway. Stock size tires, 4.10 gears (not ideal for freeway), and a completely opened up air/exhaust way (cold air intake, intake manifold, heater grid delete, turbo-back straight pipe; 4" down pipe to 5" all the way back). I do have 2wd, but I think you can get into the 20's with 4wd. What rear axle ratio do you have?
Not sure about this but might be worth looking into:
http://www.dieselpowerproducts.com/p...e-cummins.aspx
Old Nov 24, 2014 | 08:22 PM
banditman's Avatar
would increasing my tire size from 265 to 285 make enough of a difference to see a visible increase in mpg?
Old Nov 25, 2014 | 10:58 AM
cougar's Avatar
More weight and rolling resistance, so probably not.
Old Nov 26, 2014 | 04:14 PM
hallio217's Avatar
http://forums.4wdmechanix.com/topic/...el-efficiency/
Old Dec 11, 2014 | 01:26 PM
caper's Avatar
on my 98 12v I run 265s Mishilen Ltx load range E and run them at 70 front and 60 psi rear on 2007 alum rims and I run 285 bfg ats load range E on my stock steel rims at 40 psi due to rim being too narrow and causing ballooning / center tire wear , There is no comparison between the 2 for power and millage , I swap them out quite regularly when towing my travel trailer , the narrow tire with mild thread pattern on the CORRECT width rim for that tire and aired up near max is the way to go , I may try 255/85/16 toyo m55s next on my stock steel rims
Old Dec 12, 2014 | 05:09 PM
nascar mark's Avatar
An Edge EZ and a set of Bosch RV275 injectors would gain you approx. 2.5 - 3mpg
bcool
2nd Gen All Products
Oct 11, 2016 04:45 AM
summerog
Dec 16, 2013 10:01 AM
steafe
15
Jan 21, 2011 08:44 AM
jsteezy1290
Oct 8, 2005 11:09 AM
Floyd
Jun 7, 2005 01:44 PM
