Dual HID Installation on 2001 Ram
Purchased aftermarket projector low beam headlamps with separate high beam headlamp. Installed them and the computer didn't like what I did. Highbeams worked, but for low beams both high and low beams turned on but with low illumination.
As I was planning to install HID bulbs and ballasts in both low and high beam positions, I purchased canbus ballasts. Thought my issue would go away but it didn't.
The three-way plug for the aftermarket headlight assembly has two power wires and a common ground. So each canbus ballast uses one of the power wires but they share the common ground.
Any idea what I did wrong?
You need some resistors to fool the CAN-BUS into thinking that the original lights are there.
Call the company you ordered your kit from and let them know this is your issue, and you need the resistor kit for your truck.
-Kris
-Kris
Yeah, from an HID website I jumped on was on it looks like the black wire is quite possibly NOT ground, that it's a power wire and the red wire and white wires are ground for the two filaments. I'll use a voltmeter on the pins to confirm.
You're correct… I got it done with the pin swap. Through my testing I also realized that the headlight system is grounding system to activate the headlights and change from low beam to hi.
Because I have dual HID and the lamps take a couple seconds to warm up I now need to figure out how to keep the low beams on when the highbeams are turned on.
I saw another post from a few years back wherein a couple of wires under the steering column are bridged to accomplish this, so I'll look into that.
I have the Dodge manual so I can look that up… If it's as easy as that then that shouldn't change the amount of draw as they would be separate circuits I would imagine… Don't want to start engine fire
J Banning
Aug 30, 2010 10:19 PM
angleiron
Feb 21, 2007 07:44 PM
223 rules
Nov 1, 2006 06:12 PM
Lightman
May 3, 2004 08:53 PM
