160 vs. 215 pump - getting simaler power
Old Dec 21, 2005 | 12:29 PM
tmacie's Avatar
Ok I have a 94 auto so it's got the 160 pump. It'll have a Goerend transmission soon, so that won't be a worry. So what do I need to get my pump up to snuff with the power a 215 could put out?
I did a bit of searching and couldnt find exactly what I am looking for.
Thanks,
Travis
Old Dec 21, 2005 | 12:39 PM
TxDiesel007's Avatar
You can get a 160 pump
to put out insane amounts of fuel as well. Delivery valves (laser cuts) and u will flow more fuel than a stock 215 pump. Some internal pump work would also probably be needed as well as timing the injector pump. After all fuel and air equals power with these diesel engines...
Tx
Old Dec 21, 2005 | 12:55 PM
tmacie's Avatar
So does a modded 160 have the capability of putting out the power of a modded 215? I wouldn't think so, but hey....I'm new to this!!
Thanks,
Travis
Old Dec 21, 2005 | 01:03 PM
SHARPMACHINE's Avatar
No, but a 160 can go to about 450 with laser cuts 370's, a big plate and some governer springs. Of course you would hae to contend with the turbo before that point. Keep looking around and you will see. Do a search on CTDNUT, he runs quit a bit on a 160 pump. Their are others as well.
Old Dec 21, 2005 | 01:06 PM
tmacie's Avatar
Cool. thanks for the info. im looking for about 450. nothing too wild. I didnt think id need a 215 to get to where I need but was just curious.
Travis
Old Dec 21, 2005 | 02:34 PM
Big Deezul's Avatar
a turbo upgrade should be what you start to research next...the 12V can all give you a ton of fuel for a fairly decent price, but getting enough air to use it with out overheating is the real issue, at least from what I have been reading the last few days
Old Dec 21, 2005 | 05:01 PM
got...DIESEL?'s Avatar
what you read is correct.....I'll re-affirm that. At sea level in 65* air with 70% humidity, heat is still a real SOB with the stock or even a hybrid with the common 12v go fast parts. I've about reached the end of the road with my 160 pump...and the compounds are goin in this month. I'll be looking for a 913 pump soon.
Old Dec 21, 2005 | 06:11 PM
wana12v's Avatar
piers stoopid is based off of a 160 dosent answer your question but seemd relevant to me
Old Dec 21, 2005 | 08:19 PM
hotmopr's Avatar
You can get mid 400s with the 160. Look at my signature. I have never been on a dyno, but 13.90s in the quarter at 6500 lbs... Close to 430-450 hp..
Old Dec 21, 2005 | 09:18 PM
I raced an SRT/4 that had proof of a 13.7 up in Anchorage and beat him.....but that was before the NV4500....so I don't know what that makes my ET or horsepower back then, as we don't have a track here, but it has to be in that neighborhood as well.
Old Dec 21, 2005 | 10:00 PM
Underpsi's Avatar
Piers uses the 160 pumps cuz he strips them and builds them up to stoopid pumps. Why strip an already good pump like a 215 or even 180 when theres all kinds of low powered 160's around?
Old Dec 22, 2005 | 09:51 AM
12valve's Avatar
so my question is, cant we modd our pump, to be similar to the piers stoodid pump? what would we need?
Old Dec 22, 2005 | 12:50 PM
Mav's Avatar
Mav
Yea thid doesnt make sence to me either. If piers stoopids can make extreme power than why cant a 160 or 180 pump make extreme power? It might take alot of work tho. You might just be better off buying a stoopid pump
Old Dec 22, 2005 | 01:17 PM
wana12v's Avatar
you wouldn't be able to calibrate it, but you could probably put in larger barels and plunger (13mm) and a 215 cam and it would be a pretty hot pump
The stupid has a custom ground cam
Old Dec 22, 2005 | 01:34 PM
CTD NUT's Avatar
I can reaffirm that......my 94 160 pumped 2500 weighs 6680 lbs with a full tank of fuel and me in it. With a 4WD launch at 10 psi, it ran 13.90 @ 101 mph......so, I know it is around the 450 hp range. A 3000 GSK, #100 plate and laser cut DV's are the only pump mods - no internal mods. Piers uses the 160 pump to base the stoopid pump on because because there is no benefit to using a larger pump when huge plungers and a custom cams are used. Any hp P-pump would require the same mods to make it flow 800cc's like the Stoopid does!! Others have clearly exceeded 450 hp with a relatively stock 160 pump so I wouldn't say 450 hp is the ultimate limit, though, it is getting close.
