12V max fuel ?
Old May 4, 2004 | 11:20 PM
southernsmoker's Avatar
12V max fuel ?
What other "little" things can I do to my 215hp pump to get the most fuel possible out of it without having to send it to a shop. I so far have no plate in it, about 4200 rpm spring kit, excessively cut DV's, and gutted afc housing.
Old May 4, 2004 | 11:35 PM
hotmopr's Avatar
Hows it run?
Old May 4, 2004 | 11:50 PM
Haven't got it runnin' yet.
Old May 4, 2004 | 11:53 PM
hotmopr's Avatar
Did you make your own dvs?
Old May 5, 2004 | 01:17 AM
dsljunkie's Avatar
Sounds pretty maxed out as it is . Have you done the gov. arm adjustment?
Scott
Old May 5, 2004 | 09:52 AM
About any shop can cut DV's as far as you want. I wasn't aware that the gov. adjustment was useful without a plate or afc control. SS
Old May 5, 2004 | 10:54 AM
gunracer1's Avatar
how much timing are you planing on running, i would think without a plate you will need a bunch to burn the fuel that will be going in late.
Old May 5, 2004 | 03:07 PM
Somewhere between 25* and 30*. This is a pull only truck. I've run 29* in my other 97' and knock was pretty bad but top end was unreal. I put it back down to 22* for daily driving. SS
Old May 5, 2004 | 11:28 PM
dsljunkie's Avatar
How bout the turbo setup? Twins Im presuming
Scott
Old May 6, 2004 | 12:57 AM
hotmopr's Avatar
I have no Idea how dvs work but I know mine are small. They can be cut down right? How much to be equivilent to a 181 or191? Is this possible? Sorry no access to a lazer but I can use a lathe. I cant afford to run out and buy all the fancy $hit so I have to try and make it myself unfortunatly I am lacking in diesel knowledge...
Old May 6, 2004 | 05:37 PM
Jambbii's Avatar
I am also curious to see if you can cut your own delevery valves and how you did it.
Old May 9, 2004 | 10:39 PM
matador's Avatar
What does DVS stand for?
phox_mulder's Avatar
DV's, short for Delivery Valves.
phox
Old May 9, 2004 | 10:43 PM
matador's Avatar
Ok, that makes sense. Thanks,
Matador
Old May 10, 2004 | 06:08 PM
DavidTD's Avatar
Do you know how much HP you are making now? Do you have a goal you are looking for? I seen Jeff Garmon make 710hp (uncorrected and #2 only) with a 215 pump so the fuel is there to get.
Dually Driver
13
Nov 13, 2007 09:10 PM
belfert
Sep 9, 2004 03:23 PM
GO 4LO
Feb 22, 2004 08:52 PM
fishin fever
Feb 22, 2004 08:32 PM
Zino
Aug 15, 2003 10:14 PM
