#10 plate and 16 cm housing????
Old Jan 17, 2006 | 09:39 PM
txdodge97's Avatar
Do you think i will need a 16 cm housing with a #10 plate to keep my egts lower or iwll i be alright?
Old Jan 17, 2006 | 11:08 PM
msing's Avatar
Do you work the truck like tow heavy? If not then on need for the 16 if you keep the plate back. It was when I had a 10 plate and slid it full forward that the clutch started to slip bad.
Old Jan 18, 2006 | 06:14 AM
wana12v's Avatar
Talking
with my 10 plate centered towing i had no issues i just kept the rpm up, but I had timing intake exhaust ect. I also have 4:10 which make a big diffrence. wot empty it could hit 1350 mabey 1400 after holding it for a while. now its full forward and will bury the pyro and it already nuked the clutch. (dual disk time) But I think a 10 centered a little timing 3k springs is a perfect towing setup and all you really need. it'll definately out tow a newer truck for much cheaper 330, 750 and it'll make close to 400,900 forward with timing gotta love a 215
Trooper173rd
Aug 6, 2009 07:13 PM
ajbirken
Sep 6, 2006 12:11 AM
trucksforu
Aug 1, 2005 06:57 PM
95black2615
Jul 21, 2005 09:06 PM
HOHN
Dec 7, 2003 02:07 PM
