#10 plate
Old Apr 5, 2007 | 06:02 AM
Harold Swanson's Avatar
#10 plate
There is to much smoke with plate in middle,does anyone know how it would react all the way back? Would like some idea before I go back in. Thks
Old Apr 5, 2007 | 06:47 AM
plow's Avatar
putting it all the way back would be fine it will stop the smoke on the top end, where in the powerband are you getting the most and would like to cut down?
Old Apr 5, 2007 | 08:50 AM
Buckshotram's Avatar
Have you adjusted the starwheel? You can slide the afc housing back towards the steering wheel and see how much that helps.
Old Apr 5, 2007 | 10:11 AM
Box5's Avatar
theres also a smoke screw on the back of the AFC housing. everything i've read, the 10 plate in the middle should only have a little puff on take off if u adjust everything together (starwheel, plate, AFC housing, smoke screw)
Old Apr 5, 2007 | 06:59 PM
1stGen545's Avatar
You can adjust it were it only makes a little puff off the line like Box5 said. All the way back will barely run on some trucks. You would be better off with the stock plate.
Old Apr 5, 2007 | 08:44 PM
where is the smoke screw located,I never heard of it.
Old Apr 5, 2007 | 09:13 PM
Willy91's Avatar
on top of the afc housing you took off to change the plate you'll see an 8 mm allen head, remove that aleen hean and to screw is underneath it, tun towards engine for more low end fuel, away for less. Same thing as the starwheel.
West Coast
Jul 1, 2007 02:32 PM
plow
Jul 20, 2005 08:40 PM
Rockcrawler
14
Jun 23, 2005 11:40 AM
banks twinram
Feb 5, 2005 10:38 AM
