.020" over copper headgasket
whats the deal with these, would it be a benefit or its it for crazy applications, i plan to be runnin a sledpuller 66 with jammer 5's 550-600 hp range, lemme know
Copper is available but not recommended for trucks that are daily drivers
Copper tends to have coolant and oil leaks if used everyday. They seal the combustion chambers good though. I have been running a stock headgasket for 2 years w/ arp studs and twins with no problems. I have hit over 70 lbs of boost many times, and in fact did it last night playing with a Ford Lightning. If your head is flat and the studs are put in right you can be ok with a stock gasket. I try to always let the engine get to 190 degrees before getting on it hard. I have a new head built with orings and porting but I dont plan on putting it on till mine blows. I am thinking a little n2o might speed that up but it is holding so far. Meat ball your etc gasket should be fine if you stud and have a little common sence (sp)? Tim
To run nitrous you need to O-ring your head and preferably use studs...... Also tuning on a dyno is essential to get it operating at its optimum. On another note you should probably wastegate your turbo to run giggle gas.
Doug
Doug
Doug
Doug
Justin
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Ph4tty
Apr 20, 2007 03:47 PM
TxDiesel007
Feb 18, 2007 10:42 PM
