#0 plate :(
Old Nov 30, 2005 | 11:33 AM
blackcloud's Avatar
#0 plate :(
I have a #0 plate in my truck, its in the stock location and Im really not happy with the performance. I was wondering if slidding it full foward would make that big of a difference or should I look for more power in other places?
Old Nov 30, 2005 | 11:35 AM
Crimedog's Avatar
slide that little mama forward and you should feel the difference. You'll get a bit more smoke, too.
Old Nov 30, 2005 | 11:43 AM
blackcloud's Avatar
Ok say i slide it forward and install a set of lazer cut DV's and some 370's and a 18.5 turbo housing. What kind of power and EGT's can i expect?
Old Nov 30, 2005 | 01:35 PM
Cummins4Life's Avatar
375-400hp if not a little more. (you'll be really short on air)
EGT's will go as high as you want them to.
Old Nov 30, 2005 | 01:48 PM
blackcloud's Avatar
It's nice to hear from you again Zach, It's been a while
Old Nov 30, 2005 | 04:36 PM
wana12v's Avatar
i know a 160 is difrent from a 215 but there are guys making close to 700 hp on stock dv in a 215. the plate forward and 370's and either stock 215 dv or 191 will still net you more fuel than you can use. For a better driving truck spend the money on 3 or 4k springs it'll feel a lot faster and have a much more versatile rpm range
Old Nov 30, 2005 | 04:44 PM
mr T's Avatar
u better check your gov lever adjsutment to see if ur actually hitting the plate and not under it as the rpms go up..
Old Nov 30, 2005 | 05:42 PM
Cumminsdieselboy's Avatar
Muted User
I am having the same problem with a 94 auto. We did a #0 and move it all the way forward and it will NOT smoke. and loses power and the governor arm is hitting in the correct place. Very Confusing.
Old Nov 30, 2005 | 05:56 PM
mysterync's Avatar
a set of cut dvs ,370s , 0 plate slid back star wheel up will spool a built hx40 to a wonderfully loud 70 lb of boost all so makes for a great headgasket blower
West Coast
Jul 1, 2007 02:32 PM
plow
Jul 20, 2005 08:40 PM
Rockcrawler
14
Jun 23, 2005 11:40 AM
banks twinram
Feb 5, 2005 10:38 AM
