what's proper/safe way to drill holes with Hole Saw?
Make sure teeth on the bit haven't all been bent straight. Should alternate in and out to prevent binding. Also look into different tooth counts... Some better for steel others for wood... Small count, Large tooth generally works better on the wood and a large count, small tooth normally is less 'grabby' on the metals..
Slow speeds generally best and cutting fluid if going through the metal as well. Agree with above handle is necessary.
thanks for all the advice.
when i put the magnum back in the locker, i saw the handle off a dewalt laying around, i will see if it fits.
also had a cheapo black & decker, it should be low torque, i will use it next time
had not thought about a better drill being part of the problem.
edit:
the dewalt has a bend in it somewhere, it wobbles some
but i will try it next time, set the clutch.
always better to let the drill take the hit, instead of me.
especially with the post about missing scalp......YIKES...
edit:
i wasn't clear, we are just drilling the wood, and not thru the metal. that one shot just shows the wood removed, and that's the wheel well metal under it.
you try to position the tie downs so either (or both) bolts go thru the metal frame ribs, for strength.
so part of the hole is REAL close to the metal, and it often catches at the bottom, that's expected, and you just go slooooooww
IIRC, that was labeled a "bi-metal saw"
meaning it could cut wood & metal, but it looks to coarse for metal to me.
Definitely better off with a cordless with clutch for that. Corded Power drills will kick your butt, especially if you're missing the side handle. I own one corded drill, Dewault Hammer drill and I only use it when I'm going through concrete...Which means it's been used twice in the last 6-7yrs. Other than that everything is cordless with clutch.
I've done lots of those.
Take a rag and some solvent and get that tar looking build up off the hole saw.
Other than that, I brace myself with my leg to keep the drill straight, and feed it in slowly with gentle pressure at fairly high RPM.
Also, depending on the D rings you are putting in, you may not have to go nearly that deep. Mark the depth you need on the side of the hole saw, and pop the wood out with a small chisel or even a screwdriver.
High speed bit with low down pressure is better for a clean hole and less grab.
Also you can try a forstner drill bit, very clean hole but they remove all the material and do not leave a plug. Another good thing about them is you do not have to drill through to get the hole you need if it happens to be less than he thickness of the wood you are drilling.
Not to point out the obvious but I will say it anyway...Safety Glasses BEFORE you start blowing the chips out of the hole. There is glue all over the saw as well, when it gets hot it is going to grab the sides of the hole. As stated before, clean the bit
You absolutely cannot be succesful while holding it as shown in the picture. As soon as it tries to catch the grip off to one side makes it instantly bind. Use the extra handle set opposite the grip or get a hold of the body of the drill with one hand and get down on your knees.
Drill the pilot hole first with another drill. This way the hole saw won't suddenly come in contact and bind as the pilot breaks through the other side. Go slow and feed lightly. Pull out and clear the teeth periodically. Also, if you sort of orbit the top of the drill around (once you've got a nice groove) as you go, it will make a slightly bigger hole and bind less, plus it cuts faster this way and clears the chips.
Generally, dry plywood cuts very well with a hole saw. It's damp dimensional lumber that is frustrating.
AlK
Sep 25, 2008 12:41 PM
CORed
24
Feb 20, 2008 10:14 AM
1969mach1
Apr 5, 2007 07:47 PM
Dan_K
Sep 20, 2005 08:39 PM
