Tuning twin CB antennaes
Old May 19, 2006 | 05:04 AM
radshooter's Avatar
Going to try to finish my CB install this weekend. Never tuned twins before. They will be on stake pocket mounts right behind the cab.
When I make adjustments for SWR, do I adjust both of them at the same time, or adjust one for lowest SWR then start on the other antenna?
Thanks.....Steve
Old May 19, 2006 | 05:35 AM
butchera's Avatar
If they are adjustable (don't have to cut), do one at a time and then check them together. they should be close then but you may have to tweek it just a little.
Old May 19, 2006 | 06:25 AM
radshooter's Avatar
Thanks Butch. Yes, they are adjustable. They have little stingers and a set screw on the top of them. I guess I will just play with one of them to get the lowest possible SWR, then start adjusting the other to bring the SWR down even more. Sounds like a lot of trips in and out of the bed and up onto the toolbox. Oh well.....All in the name of progress.
Thanks
Steve
Old May 19, 2006 | 06:46 AM
hotdram's Avatar
Rad,
Try this link: Firestik
There is a ton of links with technical info there. Sure to be something useful for ya
~RoB
Old May 31, 2006 | 10:20 AM
Commatoze's Avatar
The correct way is to attach one feed line to a 50 ohm dummy load while you tune one antenna. Then switch the dummy load to the feedline of the antenna you just tuned, and tune the remaining antenna. The phasing lines should be included during the tuning process.
Old May 31, 2006 | 10:41 AM
darkvader's Avatar
just get francis antennas. they are matched. know that you are going to be very directional.
Clark
Old May 31, 2006 | 09:47 PM
BigBlue's Avatar
There's a CB shop back home that tunes them for free or a small charge ($5). Something to think about.
Old Jun 1, 2006 | 01:58 PM
Saxet Nomad's Avatar
Thanks
Steve
Buy your buddy a six pack and let him set in the cab, beer in one hand, mic in the other, and in between sips he can yell out "better" or "worse"...I'm free his weekend, but you live too far...It'd cost you a case...
nrussell
Jun 17, 2009 04:17 PM
hardtarget870
15
Feb 16, 2009 02:35 AM
1974d2004x4
13
Oct 17, 2007 07:47 AM
BigBlackBeast05
Jul 24, 2005 09:47 PM
rigidrotor_rt
Apr 11, 2003 09:33 PM
