Troy Built lawn mowers.Any good?
Old Dec 5, 2007 | 06:43 AM
RoadDiesel's Avatar
..well I've been lurking the used sites for a replacement mower..I had a sears 21" & its going to be replaced.( never sears lawn equipment again for me. parts usually have to be Ordered on line...wait 10 days or more, & HIGH shipping charges..sears su*k!!) anyway I found a 33" cut self propelled walk behind troy build..dealer NEW left over for some time.. list $1399.00 on sale, last one for $699.99..I did a little checking & heard negative reports for the thing..such as uneaven cut leaving a "Ridge line" of grass,wheels in front failing after little use,blade mounts falling out.. .its a 9hp Bridges/stratton engine..any comments & thanks in advance.
Old Dec 5, 2007 | 08:51 AM
doomgaze's Avatar
Troy-Bilt is a MTD product. If you want my personal opinion stay away from anything MTD makes. Some things will last a while and others won't last a week. On the flip side, MTD products are usually a lot easier to get parts for than AYP products (who make Craftsman mowers).
Unfortunately, between AYP and MTD they make just about everything you can buy at chain stores.
EDIT: Saw you mentioned the Troy-Bilt was from a dealer. You may want to do some homework. I don't know if Troy-Bilt from a dealer is the same as Troy-Bilt at Lowes/TSC/etc. For example, John Deere tractors at Home Depot are NOT the same as the tractors at a dealer. Could have changed in the past year or two since I've been out of the market, but Scotts made the JD tractors for the chain stores last I knew.
Old Dec 5, 2007 | 10:22 AM
dssimecek's Avatar
A lawn professional in Houston who has been in it for years gave me the following advice. "It is not the brand of mower, but be SURE it has a Briggs and Stratton engine." I know some of the mowers have a 5 year warrenty.
FWIW
Old Dec 5, 2007 | 10:33 AM
doomgaze's Avatar
I don't really know if I agree with that advice. We had more B&S stuff come in for repair than anything else. I have figured out that some people swear by B&S and some people swear off of them! (Just like the big three trucks I guess).
Honda has some small engines out for mowers. Personally, I would go that route. Honda has come a LONG way in the small engine department.
Old Dec 5, 2007 | 10:43 AM
mcoleman's Avatar
I prefer to be sure that it has a Kohler engine. I've learnt from experience to stay away from Briggs and Tucumesh both at all costs. I'm still running a 1992 Sears 18hp Kohler magnum garden tractor that Dad bought new. it runs great, has never been rebuilt and parts are just a click and 5 days away through Sears parts.com although the only thing to go bad in 15 years is a wear bushing in the steering and the switch on the dash for turning the blades on. My former in-laws have went through 3 John Deeres purchased at the local deere dealer in this same time frame and only mow about an acre compared to my 3 acres. The decks and steering mechicanism failed on all of them. The Deeres aren't built a bit different than the MTD mowers until you step up into the heavier garden tractor models. Same stuff different color but more cost. Unless your buying a bigger garden tractor type model pretty much all of the little lawn tractors are built the same. I would shoot for one that you can get parts for the easiest and that you have seen around awhile.
Old Dec 5, 2007 | 01:12 PM
223 rules's Avatar
I've got a husquavarna with a kohler 15 hp for the last 8 or 9 years and it has given me no trouble whatsoever. I just change the oil and air filter and it does the rest. It has about 180 hours on the engine.
Old Dec 5, 2007 | 01:27 PM
Shovelhead's Avatar
Administrator / Scooter Bum
The old, original Troybuilt products were built like tanks with fully welded seams on the housings.
The newer MTD stuff, not so much. ....everything is stamped parts.
I bought a Troybuilt snow thrower in '96 powered by a Techumseh Snow King 8hp engine.
It still runs strong like the first day I bought it.
The housing is a little scratched, but still tough as nails.
Old Dec 5, 2007 | 01:35 PM
grantx5's Avatar
"...heard negative reports for the thing..such as uneaven cut leaving a "Ridge line" of grass..."
That is exactly what I am experiencing with mine. Overall, it runs great, starts every time, I can't complain about stuff breaking. Had mine for 8 years now but it cuts UNEVEN, drives me mad.
Keeping the blades new and sharp helps with the unevenness but it's kind of a pain.
Otherwise, I think it's a pretty good little tractor and the B & S engine has been solid.
Old Dec 5, 2007 | 07:16 PM
RoadDiesel's Avatar
Hey grantx5..here is a copy & paste from some research I've done about the en-even cut..taken from another site and pasted )
****The only real flaw is the blades, not much lift to them so if your grass is long and thin or really dry it tends to want to leave a ridge in the middle. I modified a set of blades from another mower that had taller sails and they work fantastic but it takes a die grinder and lots of patience to do that.***
Thanks for the great information on this site !!!!!!!!!!
Old Dec 5, 2007 | 08:54 PM
grantx5's Avatar
Great info, thanks.
Old Dec 5, 2007 | 09:37 PM
dj_souvlaki's Avatar
my personal preferance is anything with a honda engine.
are you only looking for a walk behind?
Old Dec 5, 2007 | 09:41 PM
rustyshakelford's Avatar
we have them at work. they are stupid IMO. i would never buy one for myself
brett
Mexstan
Nov 14, 2014 08:32 AM
kingofdodge7131
Mar 3, 2013 10:59 PM
Twodiesels
Oct 6, 2009 12:10 AM
dieselcrazy
Apr 28, 2006 05:39 PM
