?? on new house construction
Old Sep 29, 2009 | 10:16 PM
Rpainter's Avatar
Originally Posted by annabelle
Well depth will depend on the soil, but 12-18" thick should be fine.
I think you might be reading it wrong or I am one of the two. his footers are 4' in the ground. the actual footer is only 6" thick and 2' wide. I think
Old Sep 29, 2009 | 10:20 PM
annabelle's Avatar
Where does the 6" come in?
Old Sep 29, 2009 | 10:21 PM
Rpainter's Avatar
thickness of his actual footer
Old Sep 29, 2009 | 10:23 PM
annabelle's Avatar
Well if it is 4' deep and 2' wide, that only leaves length.
Old Sep 29, 2009 | 10:26 PM
RAMRODD's Avatar
Originally Posted by Rpainter
that footing has got me confused also. I would much rather have a 12"x12" footer anyday of the week. that is plenty for a 8" wall. hope they put rebar in the walls
There is a pile of rebar laying beside the forms.
House is a 2 story with a walkout basement.
Tomorrow I am going to find out a few things. I here nothing but good thing about this company so I guess I will see.
Old Sep 29, 2009 | 10:27 PM
Rpainter's Avatar
I dont think the actual concrete is 4' thick. I think the hole for the footer is 4' in the ground . the actual concrete footer is 2' wide and 6" thick?? reread post 3
Old Sep 29, 2009 | 10:37 PM
annabelle's Avatar
Should have rebar 3" from the ground and 1 and 1/2 " from the sides. I would expect at least a matt of rebar, even if it is only 6" in depth.
Old Sep 30, 2009 | 08:52 AM
rich's Avatar
we dont have a frost line here but we have never poured any concrete without any steel in it. we've done some tension cable slabs and they even have rebar in the footers. fiberglass in the concrete doesnt hold it together like steel does. all the curbs we have poured have had at least one line of rebar in them
Old Sep 30, 2009 | 04:02 PM
reblerider20's Avatar
DTR'S RESIDENT NIGHT MECHANIC AND WELDER
in az we use post tension slabs and they have rebar mat and a really small footer then they run steel cable though and after in cures then they come back and tighten up the cable.
Old Sep 30, 2009 | 08:13 PM
annabelle's Avatar
Those are poured monlithically....yes?
Old Sep 30, 2009 | 09:02 PM
yes
Old Sep 30, 2009 | 09:13 PM
annabelle's Avatar
Since they already poured the footing with no rebar protruding from the footing for a connection, I would think they are going to use the footing (actually stim wall in this case) and are going to pour a floating slab,
Old Oct 1, 2009 | 09:24 PM
rich's Avatar
yea but i would say you still need steel in the footing to keep it together
Old Oct 2, 2009 | 05:40 PM
BTM's Avatar
BTM
Before getting into hvac, I was a mason for 23 years. I calling BS. on the no re-bar in the footings!! Look at the structual drawings and or details to see what it calls for. If the architect passes this (from the structual engineers' specs.) then fire him! Get involved. Take care of this now before any warranty period expires! Rich
I PASS GAS
Aug 30, 2010 11:08 PM
Checkmate
Oct 25, 2008 11:45 AM
12PACK
Jun 16, 2004 04:40 PM
May 28, 2003 10:04 PM
