More Humor
HEALTH QUESTION & ANSWER SESSION
Q: I've heard that cardiovascular exercise can prolong life. Is this true?
A: Your heart is only good for so many beats, and that's it... don't waste them on exercise. Everything wears out eventually. Speeding up your heart will not make you live longer; that's like saying you can extend the life of your car by driving it faster.Want to live longer? Take a nap.
Q: Should I cut down on meat and eat more fruits and vegetables?
A: You must grasp logistical efficiencies. What does a cow eat? Hay and corn. And what are these? Veget ables. So a steak is nothing more than an efficient mechanism of delivering vegetables to your system. Need grain? Eat chicken. Beef is also a good source of field grass (green leafy vegetable). And a pork chop can give you 100% of your recommended daily allowance of vegetable products.
Q: Should I reduce my alcohol intake?
A: No, not at all. Wine is made from fruit. Brandy is distilled wine, that means they take the water out of the fruity bit so you get even more of the goodness that way. Beer is also made out of grain. Bottoms up!
Q: How can I calculate my body/fat ratio?
A: Well, if you have a body and you have body fat, your ratio is one to one. If you have two bodies, your ratio is two to one, etc.
Q: What are some of the advantages of participating in a regu lar exercise program?
A: Can't think of a single one, sorry. It may allow you six more months in a nursing home in diapers. My philosophy is: No Pain...Good
Q: Aren't fried foods bad for you?
A: HELLO! YOU'RE NOT LISTENING!!!. Foods are fried these days in vegetable oil. In fact, they're permeated in it. How could getting more vegetables be bad for you?
Q: Will sit-ups help prevent me from getting a little soft around the middle?
A: Definitely not! When you exercise a muscle, it gets bigger. You should only be doing sit-ups if you want a bigger stomach.
Q: Is chocolate bad for me?
A: Are you crazy? HELLO ... Cocoa beans--another vegetable!!! It's the best feel-good food around!
Q: Is swimming good for your figure?
A: If swimming is good for your figure, explain whales to me.
Q: Is getting in-shape important for my lifestyle?
A: Hey! 'Round' is a shape!
Well, I hope this has cleared up any misconceptions you may have had about food and diets and remember, Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways - Chardonnay in one hand - straw berries in the other - body thoroughly used up, totally worn out, and screaming - WOO HOO! What a Ride!"
A Hunter walking through the jungle found a huge dead dinosaur with a pigmy standing beside it. Amazed, he asked: "Did you kill that?". The pigmy said "Yes." The hunter asked "How could a little bloke like you kill a huge beast like that?". Said the pigmy: "I killed it with my club." The astonished hunter asked: "How big is your club?" The pigmy replied: "There's about 60 of us."
After every flight, Qantas pilots fill out a form, called a "gripe
sheet," which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form,and then
pilots review the gripe sheets before the next flight. Never let it be said
that ground crews lack a sense of humor. Here are some actual maintenance
complaints submitted by Qantas' pilots (marked with a P) and the
solutions recorded (marked with an S) by maintenance engineers.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mo! de produces a 200 feet per minute
descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny. (I love this one!)
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
And the best one for last .................
P: Noise coming from under instrument panel. Sounds like! a midget
pounding on something with a hammer.
S: Took hammer away from midget
descent.
P: IFF inoperative.
S: Cat installed.
Originally Posted by PistolWhipt
I didn't know that Quantas airplanes were equipped with IFF (Identification, Friend or Foe) .... must serve as the Australian Air Force when they aren't fully booked
PISTOL
.PISTOL
"SNOPE"d it and found again that is is usally attributed to military ground crews.
Also found some "additions" that were not on the original list.
Defect: The autopilot doesn't.
Action: IT DOES NOW.
Defect: Seat cushion in 13F smells rotten.
Action: Fresh seat cushion on order.
Defect: Turn & slip indicator ball stuck in center during turns.
Action: Congratulations. You just made your first coordinated turn!
Defect: Whining sound heard on engine shutdown.
Action: Pilot removed from aircraft.
Defect: Pilot's clock inoperative.
Action: Wound clock.
Defect: Autopilot tends to drop a wing when fuel imbalance reaches 500 pounds.
Action: Flight manual limits maximum fuel imbalance to 300 pounds.
Defect: #2 ADF needle runs wild.
Action: Caught and tamed #2 ADF needle.
Defect: Unfamiliar noise coming from #2 engine.
Action: Engine run for four hours. Noise now familiar.
Defect: Noise coming from #2 engine. Sounds like man with little hammer.
Action: Took little hammer away from man in #2 engine.
Defect: Whining noise coming from #2 engine compartment.
Action: Returned little hammer to man in #2 engine.
Defect: Flight attendant cold at altitude.
Action: Ground checks OK.
Defect: 3 roaches in cabin.
Action: 1 roach killed, 1 wounded, 1 got away.
Defect: Weather radar went ape!
Action: Opened radar, let out ape, cleaned up mess!
A man once spent days looking for his new hat. Finally, he decided that he'd go to church on Sunday and sit at the back. During the service he would sneak out and grab a hat from the rack at the front door.
On Sunday, he went to church and sat at the back. The sermon was about the Ten Commandments. He sat through the whole sermon, and instead of sneaking out he waited until the sermon was over and went to talk to the minister.
"Father, I came here today to steal a hat to replace the one I lost. But after hearing your sermon on the Ten Commandments, I changed my mind."
The minister said, "Bless you, my son. Was it when I started to preach 'Thou shall not steal' that you had a change of heart?"
The man responded, "No, it was the one about adultery. When you started to preach about that, I remembered where I left my hat."
Here's one you can e-mail to all your friends!
I want to thank all of you who have taken the time and trouble to
send me your chain letters over the past few years. Thank you for
making me feel safe, secure, blessed, and wealthy.
Because of your concern. .
I no longer drink Starbucks as they don't support our troops.
I no longer drink Coca Cola because it can remove toilet stains.
I no longer drink anything out of a can because I will get sick from
the rat feces and urine.
I no longer use Saran wrap in the microwave because it causes
cancer.
I no longer check the coin return on pay phones because I could be
pricked with a needle infected with AIDS.
I no longer use cancer-causing deodorants even though I smell like a
water buffalo on a hot day.
I no longer go to shopping malls because someone will drug me with a
perfume sample and rob me.
I no longer receive packages from UPS or FedEx since they are
actually Al Qaeda in disguise.
I no longer shop at Target since they are French and don't support
our American troops.
I no longer answer the phone because someone will ask me to dial a
stupid number for which I will get the phone bill from hell with calls to
Jamaica, Uganda, Singapore, and Uzbekistan.
I no longer eat prepackaged foods because the estrogens they contain
will turn me gay.
I no longer eat KFC because their chickens are actually horrible
mutant freaks with no eyes or feathers.
I no longer date the opposite sex because they will take my kidneys
and leave me taking a nap in a bathtub full of ice.
And I no longer sit down on any restaurant toilet seats because the
infamous butt spider could be nesting there and send me to a certain
death with one sting.
Thanks to you, I have learned that God only answers my prayers if I
forward an email to seven of my friends and make a wish within five minutes. (Jeeze, the BIBLE didn't mention it works that way!)
I no longer have any savings because I gave it to a sick girl who is
about to die in the hospital (for the 1,387,258th time).
I no longer have any money at all, but that will change once I
receive the $15,000 that Microsoft and AOL are sending me for participating in their special e-mail program.
Yes, I want to thank all of you soooooooo much for looking out for me!
I will now return the favor.
If you don't send this e-mail to at least 1200 people in the next 60
seconds, a large bird with diarrhea will poop on your head at 5:00
PM this afternoon and the fleas of a thousand camels will infest your crotch and your arms will be too short to scratch.
I know this will occur because it actually happened to a friend of a
friend of a friend's neighbor's cousin and he's a lawyer.
cancer.
will turn me gay.
The only way to pull off a Sunday afternoon quickie with their 8 year old son in the apartment was to send him out on the balcony with a Popsicle and tell him to report on all the neighborhood activities. He began his commentary as his parents put their plan into operation:
“There's a car being towed from the parking lot", he shouted.
A few moments passed ... "An ambulance just drove by"
A few moments later, "Looks like the Anderson's have company", he called out.
"Matt's riding a new bike....."
"The Coopers are having sex!!"
Startled, Mother and Dad shot up in bed!!! Dad cautiously asked, "How do you know they are having sex?"
"Jimmy Cooper is standing on his balcony with a Popsicle too."
A guy was sitting quietly reading his paper when his wife walked up behind him and whacked him on the head with a magazine.
"What was that for?" he asked.
"That was for the piece of paper in your pants pocket with the name Laura Lou written on it," she replied.
"Two weeks ago when I went to the races, Laura Lou was the name of one of the horses I bet on," he explained.
"Oh, honey, I'm sorry," she said. "I should have known there was a good explanation."
Three days later he was watching a ballgame on TV when she walked up and hit him in the head again, this time with the iron skillet, which knocked him out cold.
When he came to, he asked, "What the heck was that for?"
She replied, "Your horse called."
