Idle problem on 2003 Yukon
Old Jul 19, 2009 | 11:25 AM
Barry Smith's Avatar
I ran the battery down and ever since it idles around 300 or 400 rpm it's always idled low around 600 rpm but now its too low. Any ideas where to look? I put a new battery in it. It is a 2003 Yukon with the 5.3 V8.
Old Jul 19, 2009 | 11:53 AM
Fronty Owner's Avatar
I would start by going to AZ and see if there are any engine code.
Old Jul 19, 2009 | 12:08 PM
Hvytrkmech's Avatar
Low voltage can cause some weird drivability issues. The tps may need to be reset or replaced? I think you will need to have it scanned with a scanner that does more than generic obdII.
Old Jul 19, 2009 | 01:05 PM
cbtumedic's Avatar
One thing to try is doing a hard reset on ECM, (used to lots of them on cadillacs after dead batteries to solve driveability complaints) what you do is disconnect both cables from battery and jumper them together, leave it that way for at least 30 seconds to a couple of minutes and then reconnect everything, sometimes that will work, otherwise get the codes checked and let us know what it has.
Old Jul 21, 2009 | 10:15 AM
Thanks guys for the replys I'll try the hard reset. And have it scanned.
Old Jul 21, 2009 | 10:17 AM
Could you tell me what the TPS is? How do you reset it?
Old Jul 21, 2009 | 06:19 PM
Number47's Avatar
TPS= Throttle Position Sensor. i've worked on a lot of GMs and never had to replace one.
Old Jul 23, 2009 | 09:30 AM
dj_souvlaki's Avatar
make sure the key is on when you touch the battery cables together.
TravisDj
Cummins Conversions
28
Mar 26, 2008 02:05 AM
Hondo
Apr 4, 2006 02:02 PM
xp8103
Apr 25, 2005 09:11 AM
Garnet Kid
Apr 22, 2004 11:08 PM
VPI
Jan 7, 2004 09:16 PM
