I need a Lincoln mechanic!!!
Old Mar 22, 2005 | 11:41 AM
FiverBob's Avatar
Which one of our fantastic members can tell me the layout of the cylinders in a 4.6 liter Lincoln engine? Looking down into the engine, what is the physical layout of the cylinders? In other words, which coil is number 1, 4, 7 etc.
DuhhhhhBob
Old Mar 22, 2005 | 12:45 PM
Copenhagenjunkie's Avatar
I can look it up on alldata for ya. What year? I might be able to send you the info e-mail.
Old Mar 22, 2005 | 01:13 PM
FiverBob's Avatar
Hey, that's a cool site - - never heard of it before, but I notice you must be a member to get information. The TC is a 2001. I put the computer on it and it shows problems with #5. First step of course is change out the coil and plug and see if that helps. Got the coil, suddenly realized I don't know the layout of this engine. DUH
If you could find that out you would be one good man - - of course Lincoln will not tell you. Now why am I not surprised?
Bob
Old Mar 22, 2005 | 01:14 PM
WhiteSport600's Avatar
Drivers side from front of engine to back is cyl: 1,2,3,4
Pass side from front of engine to back is cyl: 5,6,7,8
I've owned a few 1000hp 4.6's...lol
Old Mar 22, 2005 | 01:15 PM
FiverBob's Avatar
Hey, good man. Thanks loads. Hopefully this will get this back up and perking. Appreciate it. Supposed to be a good tough engine.
Bob
Old Mar 22, 2005 | 01:20 PM
Well, Alldata says Pass side is 1-2-3-4, Other is 5-6-7-8
Old Mar 22, 2005 | 01:42 PM
DOOOOH!!! You are right! I had it bass akwards. sorry about that, it's hard to think of when the car isn't in front of me...
Old Mar 22, 2005 | 04:00 PM
BIG MIKE's Avatar
These 4.6 engines are known for shorting out plug wires where they turn down from the valve cover, to snap on the spark plug. BIG MIKE
Old Mar 22, 2005 | 05:30 PM
FiverBob's Avatar
OK OK, boy am I glad I am slow. At least I didn't BOMB the wrong cylinder.
So, 1 on passenger side, 5 on drivers side. Correct? Tomorrow.
Mike - - this thing doesn't really have spark plug wires as such - - unless you mean that little tiny short thing coming out of the coil - - I guess I have been in lala land - - I was not aware these things have eight coils. Weird. And, they tell me the coils are messing up quite often. Wonder how hard to convert it over to dual Mallory coils, Magspark ignition, dual point distributor? Now, them were the days - - yeh. Plugs, points and condenser and off you go - - - now wait a minute, if my feeble memory serves me right, you went for about 10 to 20,000 miles and had to do it again. Oh well, I'll keep what I have.
Thanks again, guys.
Bob
Old Mar 23, 2005 | 11:27 AM
Have you washed your engine lately at the car wash? The 4.6 is notorious for the plug boots (the rubber part that actually goes into the valve cover) burning through and arcing to the head instead of the spark plug. If any moisture gets in between the head and the boot it'll arc through the rubber and you'll have a miss. Is it SOHC or DOHC 4.6? The SOHC's are worse about this due to the plug boots being vertical and water running directly down the holes....
99 cummins
Apr 22, 2005 12:22 PM
joel
Apr 20, 2005 02:54 PM
Geico266
Jan 4, 2005 01:08 PM
berner
Jan 19, 2003 08:44 AM
