home HVAC: should I insulate the Air Handler in the attic?
Old Jun 8, 2010 | 11:16 AM
j-fox's Avatar
This isn't what you want to hear, but get the air conditioner out of the attic!!!
And consider a metal roof. It deflects a lot of heat.
Old Jun 8, 2010 | 11:50 AM
05 dodge's Avatar
Originally Posted by 04ctd
it was built in 2004, so it's newer
soffits are open, and uncovered.
but the only vent is the Ridge vent.
Spooler, shoot me a link to your Lowes fan. anyone got link to a better fan?
what did you use to vent the other end of the attic?
my house is frame with vinyl siding.
tks guys.
http://www.homedepot.com/webapp/wcs/...atalogId=10053
Old Jun 8, 2010 | 12:28 PM
04ctd's Avatar
are you guys talking about one of these:
Master Flow Power Roof Mount Vent 1600 CFM'S
that mounts on top?
I was thinking a little traingle fan that mounts near the peak of the roof, on the siding, not on the actual top.
in the vinyl siding, on the wall, not on the roof.
i do NOT want to pull up shingles. I had a leak while back. that was a problem
Old Jun 8, 2010 | 03:18 PM
annabelle's Avatar
I,m talking about a simple attic exhaust fan you can get at Lowe's. What type roof do you have (gable or hip usually).
Old Jun 8, 2010 | 03:21 PM
annabelle's Avatar
Where does your make up air come from? Outside air or attic air. If it is outside it doesn't matter where the unit is located. I would be suprised if it came from the attic. Insulate the attic rafters.......metal roofs absorb a lot of heat too.
Old Jun 8, 2010 | 03:33 PM
AggieJustin's Avatar
Watching this topic as well. Been noticing the same thing on our A/C (first summer in a "new to us" house). Warm burst of air at startup (especially when it hasn't run for a while), then transitions to cold. All flexible ducting in the attic that I've checked over to make sure there were no leaks. I'll probably double check them now, just not looking forward to that hot attic.
I'll need to check the temps up there, but I was considering adding some power ventilation. Currently, the only vents in the roof are non-power slant vents.
Old Jun 8, 2010 | 03:54 PM
05 dodge's Avatar
that mounts on top?
Then you want a gable end fan which will work just fine. Just put a vent on other end of house if you don't have vented soffits.
Old Jun 8, 2010 | 04:33 PM
annabelle's Avatar
Depends on the type of roof you have......if it is a hip, then you don't have the option of a gable end mounted fan.
Txwelder
Dec 31, 2011 12:02 AM
jmccart
48
Jul 23, 2008 12:34 AM
Begle1
Sep 2, 2006 09:38 AM
Timmay2
Aug 15, 2006 06:02 PM
trik396
Apr 6, 2006 10:15 AM
