HELP!!! '82 F-150 Problems.
I'd say this bronco running a 390 holley and offy ( i think) intake runs very very smooth http://www.youtube.com/watch?v=-NeR2Kq_q5s
Check out his swap photos:
https://www.supermotors.net/registry/20215/68784
Do you plan to offroad on rough terrain? If so, you might want to think about an Edelbrock. You spend much time on steep angles with the holley and you might be prone to stalling with the big bowls it has. The 500 edelbrock shouldn't be too big for 300 ci.
The reason I stated that was because of the age and condition of the engine. If you tear it down and build it to support a 4bbl then I would say go for it. I think if you just throw large carburetor on it you will wind up with something that just bog's down when you mash it. Unless you are going to do some decent mods (camshaft, intake etc) I think you will be way better off using a 2bbl. You would be surprised at how will the engine will run with it on there.
What are you intentions with this truck? Daily driver, off roader, hot rod?
DD/ Hunting rig. As for the bogging thats why i'm looking for a small 4bbl. I have been looking at using a 2bbl but there seems to be more support for using a small 4bbl like a holley 390 or an autolite 4100 wiht 1.08 venturies
i found the carburator to be loose from the bace of carb to the main body tighten it up and it will be find at least i found thaton several of them over the years only thing better than a ford 4.9 is a 12vcummins but thats my openion
WVfarmboy I have already don that and it was loose but. MY problem is the PO just seemed to pull everything vacume related off and now i have a really really messed up vac. situation.
One of my buddies dad has a shop in my town, he has an enormous inventory of hard to find Ford parts. I believe the venturi style carb you are looking for was used on the 302 and 351 engines in the crown vics during the 80's. Let me do some digging and I will get back to you.
WELLLLLL I bought this one today.
http://cgi.ebay.com/ebaymotors/ws/eB...SA:MOTORS:1123
and should be winning this soon.
http://cgi.ebay.com/ebaymotors/ws/eB...m=390069189094
I have also bought an offy "c" intake and EFI exhaust Manifolds.
the truck should be running and driving soon LOL
Ok now that i have switched to an Offy intake with a 2100 autolite and efi manifolds what else needs to be done?
1. I need a way ot heat the carb.
Answers:
1. V-8 air cleaner and re attach heat riser some how maybe weld bolts to new exhaust
2. I have heard of a hot water heater/ Spacer
a. I really dont want another spacer on my carb
b. How else could i heat the carb? I live in North western ND and it get edit COLD here like -40*F
2. Whats this i hear about having to do something to my distributer? some kind of mod where i changeteh spark? It seems to run fairly smooth right now. What would thisdo for me? thanks, Kyle
ps. 2100 autolite w/1.14v I also have a 4 speed man and I chose to use a manual choke also thanks.
PS. PIX and a youtube vid to follow once i get an exhaust mounted up
Answers:
I would go with option one. A spacer will heat the mixture once it is through the carb but you will still be prone to carb icing. Also with a heated air cleaner setup, you can plumb cold air in from behind the grill and when you floor it and vacuum drops you get a nice cold mixture for max power.
Distributors for EGR engines have more vacuum advance than non-EGR applications. If you set the timing for best WOT power you will probably get light throttle ping. You need to limit the vacuum advance travel if this occurs - a simple job if you have a welder.
CrashCade
Dec 3, 2008 07:58 AM
dodgediesel
26
Nov 2, 2008 12:20 PM
curts99
Feb 14, 2008 12:09 AM
heavyJ
Oct 25, 2007 09:08 AM
Ramtuff06
Aug 21, 2007 06:21 AM
