Harmonics hardwood flooring install???
Old May 31, 2005 | 07:46 PM
AKDSLDOG's Avatar
I was suckered into buying this stuff from costco for my wifes office. First I had no idea that I needed a "install kit" , our costco doesn't have it . Next it say's if you have infloor radiant heat you need to call for install tips. Well, I've been calling and get no awnser and have not gotten a call back with my mesage I've left. I have heard you can get this padding from lowes or home depot, anyone know? Anyone have any dealings with this brand of flooring? This stuff looks to me if you piled it up and poured diesel over it, it would make a great bon fire!
FrustratedAKDSLDOGtryingtokeepwifehappy
Old May 31, 2005 | 07:50 PM
P.J's Avatar
P.J
Is it the "click" together type?
If so there is a trick to it (I have a friend in the flooring business). If I was a good type I could help, but I would be here till midnight trying to explain. The padding should be a very thin (1/8" or less) green rubber type material. Short rolls, probably 5'X 40' or so.
Good Luck.
Old May 31, 2005 | 08:06 PM
AKDSLDOG's Avatar
yep, its the click lock type. No glueing required.
Old May 31, 2005 | 08:10 PM
Homestead's Avatar
It doesn't have to be green foam. Yes green is the better stuff, but the cheapo white will work just fine. Home Depot and such carry it.
Old May 31, 2005 | 09:45 PM
spunbearing's Avatar
That stuff is a piece of cake. You basically just lay down the foam padding and measure and cut the wood strips leaving a gap around the edges which will be covered by moulding. It just clicks together. I think that the second piece has to be at about a 45 degree angle to the first piece and you push the tongue in the groove and push it down. The thing that concerns me is your radiant heat. You may need a special type of heat resistant foam.
Old May 31, 2005 | 09:55 PM
AKDSLDOG's Avatar
Yes, the infloor radiant heat is THE BIG QUESTION! The stuff looks easy to install, as I heard it is by many. Just is the normal padding ok for the infloor? or is it something else? I found a forum site for this stuff and posted there too, all posts over there seem to love this stuff and have no problems. Patiantly waiting, I should say the wife is. Gotta get this done so I can get back out in the woods and hunt!
Old May 31, 2005 | 11:11 PM
duner's Avatar
here's a forum discussion on the stuff.
http://torque.oncloud8.com/archives/000379.html
Old Jun 1, 2005 | 07:48 AM
upersleder's Avatar
only thing you need to be concerned about with the in-floor heat is that you do not get the surface temp. of the floor above 88*. i design in-floor systems and have many installed with wood flooring. mind you, this is not your water temp, but your surface temp. PM me if you have any questions about it.
Old Jun 1, 2005 | 08:47 AM
http://www.quick-step.com/tech_doc/v...%20heating.pdf
hamilton71801
Dec 19, 2011 12:20 PM
Box5
Feb 22, 2008 08:20 PM
mvanhelden
Jun 17, 2007 03:04 PM
big jimmy
Mar 14, 2006 08:36 AM
durasmack
Feb 17, 2006 01:49 PM
