drivetrain "harmonics"
Old Mar 12, 2006 | 09:09 PM
big jimmy's Avatar
My truck will make a low grade harmonic humming from between 30 mph to around 50ish, depending on load.
Seems to be coming from the passenger side of the hump in line with the seat front.
Is this normal?
Jimmy
Old Mar 14, 2006 | 08:36 AM
kd460's Avatar
Just a guess, if your exhaust is stock, there is a metal rod/support brace that is welded on to your exhaust pipe, and fits into a grommet on the trans support bracket. There is a rubber grommet that the rod fits into. If the grommet has failed or is gone, that might be the cause of your niose.
You need to crawl under the truck and check (follow the exhaust pipe). It could also be a lose trans mount, but, just guessing.
eastmentCTD600
Apr 20, 2011 02:09 PM
eastmentCTD600
Apr 19, 2011 03:22 PM
mudwisr2
Apr 11, 2008 05:29 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
AKDSLDOG
Jun 1, 2005 08:47 AM
