Drivetrain "jolt" after acceleration from stop
hello,
I have a weird symptom developing. It goes a little like this...
1.) When accelerating (light or heavy) from a stop the truck begins to move as expected, no problem from inital take off...
2.) just after the truck begins to move (say around 2 MPH) there is a drivetrain "jolt" much like one would expect to have with worn U-Joints; however, the U-joints are fine. There is no audible clunk or any other noise but a jolt can be felt just after take-off.
Has anyone experienced this? If so what was the diagnosis and/or fix?
Thanks in advance.
Thanks in advance.
Had an '87 3/4 ton (4 spd), which I bought new, that did something like this after owning it for a year or two. When coming to a complete stop, like at a light, the rear diff apparently would twist slightly and the springs would "wrap" a bit...then unload when you'd drive away from the stop...making a noticeable clunk. I think that there was a TSB out on this at the time. The dealer sprayed white grease between the spring plies and the clunk would disappear until the grease wore off. I kept a can in the truck and would lube it up whenever the clunk came back.
Oct 9, 2011 09:48 PM
eastmentCTD600
Apr 20, 2011 02:09 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
smokey196240
Jan 29, 2007 09:13 AM
