Grease- what is every one using
Old Nov 12, 2010 | 04:44 PM
Onemoparnut's Avatar
I use the lubrication engineers grease the highest of quality I have found it made a beliver out of me. It is very expensive but it is well worth the money.
Old Nov 12, 2010 | 06:15 PM
ramlovingvet's Avatar
DTR'S Chaplain
Wild-root Cream
Old Nov 12, 2010 | 07:49 PM
Fronty Owner's Avatar
Originally Posted by AH64ID
Then why are there 3 places to grease em?
where?
I have yet to find a grease fitting.
Cause its FO that why.. The only thing he greases is his hair
dont forget my stache....
Old Nov 12, 2010 | 08:09 PM
Purplezr2's Avatar
where?
I have a second gen and have replaced the balljoints and u joints
So
4 ball joints
2 front axle u joints
3 front driveshaft ujoints
2 rear drive shaft u joints
1 track bar
2 on the cross over bar for the steering
2 on the drag link
total 16 zerks
Old Nov 13, 2010 | 11:36 AM
AH64ID's Avatar
where?
Fill out your sig...
Old Nov 13, 2010 | 12:22 PM
Scotty's Avatar
Top's Younger Twin
At least it is titled grease and not lube
The only thing Scotty is lubing is his leggs
LUBE LEGGS. Sweet.
Old Nov 13, 2010 | 05:06 PM
Where are you finding it?
Old Nov 13, 2010 | 05:30 PM
Hvytrkmech's Avatar
Here you go.
http://www.le-inc.com/repLocator.jsp
You won't be sorry.
Good luck.
Old Nov 13, 2010 | 05:37 PM
Jeff in TD's Avatar
I use the red Valvoline synthetic in the grease gun and for trailer wheel bearings. It is rated nlgi cg-lb for both chassis and wheel bearings.
Old Nov 13, 2010 | 06:16 PM
Bark's Avatar
Depends on what I am greasing. Like Jeff, I use valvoline syn for a lot of auto stuff. For my hair I use Pomade and we use bacon grease for the greased sheep competition.
Old Nov 13, 2010 | 08:59 PM
Mexstan's Avatar
With all the mods I have done, my truck now has 13 grease nipples and I use the only grease that the local AutoZone stock. Grease more often than most and even more after driving in heavy rain. Still got my original tie rod ends.
Old Nov 13, 2010 | 09:02 PM
I get it through my job but I am not sure where they get it from I will try to find out on monday.
Old Nov 14, 2010 | 01:46 AM
Adaminak's Avatar
Schaeffer's Moly EP I bought 5 tubes before I moved to Alaska and have used maybe half of one. Great stuff, and I think it'll probably last me quite awhile.
Old Nov 14, 2010 | 07:12 AM
chaikwa's Avatar
We use this at our shop.
http://www.le-inc.com/products.jsp?productID=52
I switched to it about 7 years ago, since switching I have never had a dry u-joint, and king pin replacement now only happens from impact damage. I also use it to pack the front wheel bearing on all our International carriers, have not had to change wheel bears since using it. It is very expensive but well worth it in a commercial atmosphere.
Do you use their motor oils too Tim?
Old Nov 14, 2010 | 09:42 AM
Hvytrkmech's Avatar
We use their grease and gear oil at the shop Scott. We use Chevron Delo 400 LE in a bulk container for engine oil. I have been trying to get the owner to switch but he won't. I run LE engine oil (8800), tranny fluid (1150), and gear oil (703) in my personal truck and on my way to 20k oil changes with UOA.
Forty-Two
Oct 22, 2008 11:55 PM
Maccandy
Nov 17, 2005 11:50 AM
CACalomino
13
Aug 23, 2005 05:31 PM
yomitch
Feb 22, 2004 11:34 AM
