Grade 8 Bolt / Thread Die ???
Old Aug 28, 2008 | 05:43 PM
BearKiller's Avatar
Question Grade 8 Bolt / Thread Die ???
I need to cut extra threads on the unthreaded shank of two coarse 7/16 grade-8 bolts.
Reason being, I am making two long studs to hold the axle-flange, then also hold the bracket for the Veederoot Hubometer.
If the Grade-8 is too hard for my normal thread die, what if I make these two studs from regular grade bolts, seeing as how the other six bolts/studs are the good stuff ??
Thanks.
Old Aug 28, 2008 | 05:46 PM
06RAM2500's Avatar
Aren't the threads rolled instead of being cut on grade 8 bolts???
Old Aug 28, 2008 | 07:07 PM
Fronty Owner's Avatar
it would be better to visit you local bolt and screw shop and get a piece of B7 All thread and a couple 2H nuts.
the threads are rolled (faster to manufacture) and the unthreaded shaft is smaller than the major diameter of the threads.
Old Aug 28, 2008 | 07:45 PM
BearKiller's Avatar
My local bolt and screw shop consists of two bolt-bins, right next to the circular nail carousel, Grade-8s and regulars, and not a lot of either.
I have searched all of the regularly recommended sites that advertise studs and nothing they offer is what I need; so.........., I figured I would make them up myself.
What is "B7" all-thread and "2H nuts" ??
Thanks.
Old Aug 28, 2008 | 07:48 PM
carl48's Avatar
the b7 is the best way to go but a non china die will cut the threads ok and as stated the threads will not seat as deed in the nut where cut on the shank
Old Aug 28, 2008 | 08:29 PM
B7 and 2H are the ASME specs for studs and nuts that are equivilant to Grade 8 in bolts and screws.
http://www.thomasnet.com/kentucky/bolts-6214803-1.html
Old Aug 29, 2008 | 10:18 PM
BearKiller's Avatar
Thanks for pointing me in the right direction and explaining the grade specifics.
Old Aug 30, 2008 | 12:27 PM
n/p
you go into any screw shop and ask for a grade 8 stud, you will get a B7 (stamped on the end), but they will usually know what your talking about.
Grade is for bolts and screws so most people refer to all threaded hardware that way. I was guilty of that too until I started dealing with pressure vessels and bolted flange connections and learned the error of my ways.
Old Aug 30, 2008 | 01:30 PM
BearKiller's Avatar
Steam boilers ??? Locomotives ???
Old Aug 30, 2008 | 01:58 PM
BearKiller's Avatar
I found this :
http://www.mcmaster.com/
Type part# 98957A610 in the "search" if the link doesn't bring it up.
DTR-username
Oct 3, 2016 07:46 PM
FordTrax
Apr 18, 2014 08:47 PM
Dave88LX
Aug 2, 2005 11:43 PM
boughtadodge
17
Nov 30, 2002 09:47 AM
