Fuel Stabilizer for Gas Vehicles
Old Aug 20, 2010 | 03:34 AM
ofcmarc's Avatar
Originally Posted by Rednecktastic
Naw man, I had fuel in my ATV that sat for 3-4 months and it turned yellow. Filled it up on the road and it ended up immediately in the shop so I didn't have a chance and forgot to put stabil in it. It's bad for the fuel system and valves for sure.
Don't know what color the fuel was today but the Jimmy I parked last year at this time fired right up on whatever fuel was in the tank from last year. once I put a charge on the battery..........
Old Aug 21, 2010 | 11:15 PM
Rednecktastic's Avatar
The sealed fuel systems on modern cars make a world of difference. Fuel sitting in a lawnmower or ATV is exposed to a lot more oxygen and moisture than fuel in the tank of a modern car.
My ATV has a sealed fuel system, it's EFI and has many times had the lid under water. Still was yellow after sitting several months. Luckily I ran out any reminance of that fuel last weekend.
Old Aug 21, 2010 | 11:38 PM
Colo_River_Ram's Avatar
With age comes the cage
Try some Lucas fuel conditioner.. both before and / or after it has sat a while..
Old Aug 23, 2010 | 09:57 AM
supr's Avatar
I noticed in the Marine section of a local sporting goods store that Stabil Marine will trat more gallons/$ than the regular red stuff. I suspect it may be better too, as it is blended for ethanol. Your thoughts?
It would appear that ethanol is almost evreywhere now, as alcohol is cheaper than oil or gasoline, so, more profit for Big Oil. In the mean time, we need to be careful with any open fuel systems witj stuff like Stabil, to prevent expensive trips to the shop.
Old Aug 23, 2010 | 12:25 PM
You mention open full systems and stabil, are you not supposed to use stabil in an open system?
Old Aug 23, 2010 | 12:43 PM
supr's Avatar
Open systems, like ATV, Motor Cycles, boats, lawnmowers are where you should use it.
The question is if it is needed in cars that are not run a lot. It seems if you burn a tank in 6 mo's, that is enough; however, I think the Stabil, regular or marine, is low cost insurance.
hotdram
Nov 22, 2008 03:34 AM
cappykd
Jun 23, 2008 04:45 PM
THURENfab.
Aug 8, 2007 07:02 AM
Scovo1
30
May 11, 2007 01:08 PM
04ctd
15
Apr 30, 2006 08:45 AM
