Entry Door Locks???? (Stupid Smartkey/Securekey)
Old Jul 4, 2011 | 12:50 PM
hotdram's Avatar
Need to replace the deadbolt and lock on my front door.
Two most common brands, Kwikset and Schlage, have systems that let you key them how you want. Called Smartkey or Securekey. You put a master key in, do something and it "programs" the lock and the regular key, no more having to get sets keyed alike where you buy them. This is not a digital keypad type lock, just a normal lock, you still need the key. Problem is, I have read nothing good about either system. Most complaints are that they just stop working and the lock gets programmed back to some default setting making your key useless and you end up get locked out of the house. That would suck. Alot of people have had to have the cylinder replaced 2-3 times. This is unacceptable and I won't put one on my house.
I didn't see anything on the websites for Kwikset or Schlage for class I residential locks that didn't have this type of system unless you go for the keypad type entry lock/deadbolt, which look quite ugly. Not too keen on having a keypad on the front of my house anyways.
What other options do I have?
Here is a quote from one of the locksmith websites I visited. Readers commented on the article with nothing but problems. One installed said 7 of the 10 he installed quit working/locked people out.
Schlage Securekey Problems
Reports are coming in about significant problems with the new Schlage Securekey product line. Specifically, these problems include design manufacture inconsistencies and parts not performing the task for which they were designed.
Apparently, some of the internal pin tumbler workings are known to separate from the side bar element, causing keys to not work as they are supposed to.
There have been reports of the cylinders able to be re-keyed without the use of the special key provided.
People locked out of Schlage Securekey products have generally required the product destroyed and replaced, because of the apparent inability or difficulty to have a key determined.
We are looking into these claims and plan to report more as we find out.
I could add tons of these types quotes.
~Rob
Old Jul 4, 2011 | 01:27 PM
cougar's Avatar
I was one of them. It quit working within a couple of days. Locked out of my house in the middle of winter. I mailed the broken pieces (I removed it with a hammer) back to Schlage and told them where to stick there dangerous lock. They sent me a replacement and I took it to the place I bought the original from and got my money back. NEVER AGAIN! And I warn every one not to get one of these locks, it may cost you your life.
Old Jul 4, 2011 | 01:44 PM
S.TX.MEGA's Avatar
If you can get a regular lockset the same brand as your old one you can just change out the tumblers and not have to re key.
Old Jul 4, 2011 | 02:27 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Any decent locksmith should be able to change the cylinders of all your (same brand) locks to a common key.
Old Jul 4, 2011 | 02:38 PM
Dr. Evil's Avatar
Whats wrong with one of the combination ones? Been thinking about getting one of them.
Old Jul 4, 2011 | 03:52 PM
Shorts's Avatar
Uhgg, put us on the Kwikset Quit list. Probably lasted year and a half and now the key doesn't work. Least the deadbolt still works.
We've got a key pad on the garage door which is our main in/out of the house.
Old Jul 5, 2011 | 11:38 AM
cougar's Avatar
One thought about reusing your old key is they do wear out. If I have to change the lock I'd rather start with a new and different key. That would also cut down on stray keys winding up in the wrong hands.
Old Jul 5, 2011 | 09:09 PM
hotdram's Avatar
Called a locksmith today about the Kwikset stuff. You can't buy one of the new Smartkey sets and have them put a traditional cylinder in it.
The existing lock is "builder grade" (i.e. the cheapest thing around) and 12 years old. Looks like crap and is starting to stick (need to see if graphite will help a bit). Time to replace with something new and don't like the looks of a keypad on the front door.
The locksmith said he might be able to locate the Kwikset stuff I want before they added the Smartkey "feature".
We'll see. In the meantime, I am researching other brands (Baldwin and not sure who else) to see what is available.
~Rob
Old Jul 5, 2011 | 09:11 PM
hotdram's Avatar
Yes, but the problem is finding a new lockset that isn't "Smart", seems as if those can't be retro-fitted with a traditional cylinder.
~Rob
Jim Lane
Mar 23, 2013 09:31 PM
3500CTD
Apr 4, 2009 04:42 PM
WhozNxtLS1
Oct 29, 2008 09:12 PM
Apocalypse
Jul 1, 2008 12:09 PM
nomad65
Aug 20, 2007 06:01 PM
