The DTR Misfits Breakroom (10/14 - 10/20)
Just Dog it. (follow your nose)
The resistor pack (about 4 resistors) is the unit screwed to the air duct (for cooling of the resistors) behind the glove box.
Switch is bad. (from the factory) Your's is even worse at this point. Probably also toasted the connector.
After market switches tend to be even worse. After market connector replacements tend to be too light. Just put em in and Jim L's heater relay mod and it'll live a long time.
Probably the same principles apply tho, so tomorrow I'm going to pull the passenger seat and access the heater/AC box. (It's under the seat) If it's in a duct, it should be there.Got one water line fixed today and abandoned the other. The one going under the cement floor of the barn/training room/newapartment was actually easy once I found out what it was. They went from the 1 1/4" black plastic, to a 1" piece of galvanized, put a tee in the galvanized, then a hose barb, then continued to who-knows-where with the black plastic. The top side of the tee has 1/2" copper coming off of it and that is what feeds the barn. All this is UNDER the barn's cement slab. I was able to access enough of it to determine it was the black plastic that was leaking, after the tee. So I just cut the black plastic after the tee and plugged it. As far as I can tell, we still have water where it should be! Maybe I just cut the neighbors water supply! Nothing surprises me anymore around here!
The other barn's water line is leaking under the wood floor, so I made the corporate decision to leave it alone. The water isn't used in that barn anymore anyhow and the only reason we were going to fix it is because "we've always had water in that barn". Not any more!
Afternune all!
Water leaks are like vacuums.....they really suck!!!
If you're luck enough to catch it in time you can actually pinpoint where it's at.......if they go too long you can dig forever before they're found. Glad you got 'em repaired before they caused any damage.
T-Rad, that hand-check idea is too close to the truth for sausage making and by making I mean manufacturing, not cooking. As you can prolly guess, I make sausage as a hobby. The early steps in the process usually involve deboning and cutting into cubes large cuts of almost frozen pork and beef. After a few minutes of that my fingers are so cold they are numb. After a couple of near misses where I had to stop working and check to make sure digits were all still attached, I bought a chain-mail (sp??) butchers glove for my right/meat holding hand. Apparently my DW, friends and family won't eat our tasty, homemade sausage if they are 5% or greater human meat.
Naw, but I seem to go through a pair of gloves about once a month or so..
rth doing it's worth griping about doing it.Where IS the resistor Tim? I thought the $400 control panel on the dash board would control everything!
I didn't tell the WHOLE story on the headlights... I have highbeams, no lows. And when I stomp on the dimmer switch, I can get low back until some connection gets hot in the switch. I can hear little sizzling sounds coming from within either the switch or the connector!
Good idea on the butcher's glove, they work well.Evening all.
Good morning folks.....coffee's on....pretty strong today too!! Saw on the local news this morning about a bad situation on I-35 here in town. Lots of construction going on right now and last night at 10:30 a semi was going (reportedly) 10mph through the construction zone when another semi rear-ended it going 70+ mph and immediately burst into flames killing the driver of the faster truck. Bad deal.......just a month ago in the same zone a worker was hit and killed by a truck. The north bound lanes are still shut down as of 8:25 this morning.
PLEASE DRIVE SAFELY AND MAKE IT BACK HOME TO YOUR FAMILIES!!!!!
Morning.
Wish the weather would level out. Hot then cold then nice then hot, etc is killing me. Sinuses aren't happy. When sinuses aren't happy, Shorts is not happy.
I feel your pain Shorts. Mine haven't been as bad this year as they were last year.....thank goodness. My daughter on the other hand.....poor thing, she wakes up at night because she can't breathe. 40's in the morning, and back up to around 90 by Sunday......sheesh. The weather yesterday reported Waco as Texas' #2 worst city for allergies/sinuses.
Morning!
THURSDAY, OCTOBER 18th:
1767 - The Mason-Dixon line was agreed upon. It was the boundary between Maryland and Pennsylvania.
1842 - Samuel Finley Breese Morse laid his first telegraph cable.
1867 - The U.S. took formal possession of Alaska from Russia. The land was purchased of a total of $7 million dollars (2 cents per acre).
1892 - The first long-distance telephone line between Chicago, IL, and New York City, NY, was opened.
1944 - Czechoslovakia was invaded by the Soviets during World War II.
1969 - The U.S. government banned artificial sweeteners due to evidence that they caused cancer.
1970 - Quebec's minister of labor was found strangled to death after eight days of being held captive by the Quebec Liberation Front (FLQ).
1989 - The space shuttle Atlantis was launched on a mission that included the deployment of the Galileo space probe.
1990 - Iraq made an offer to the world that it would sell oil for $21 a barrel. The price level was the same as it had been before the invasion of Kuwait.
1997 - A monument honoring U.S. servicewomen, past and present, was dedicated at Arlington National Cemetery.
2006 - Microsoft released Internet Explorer 7.0.
THOUGHT FOR THE DAY:
He who laughs last, thinks slowest.
Coffee and ph00 are ready.
What? Am I late?
What? Am I late?
Excellent Tim, THANKS! (Again!)
The resistor and plug looked to be in good shape, no melting, everything intact, but I changed the resistor and made new ends to replace the plug, (remembering what you said about changing the plug), and it all works perfect now. The only way to replace the plug, according to the dealership, was to replace the whole 4 wire harness from the seat housing to the resistor, and they wanted $144 for it. It's only a foot long, but I figured I could make new ends a little more economically!
Found the rattle under the dash too. Antennae wire was knocking against the plastic duct work.
The headlight problem was the plug on the dimmer switch harness. Fixed that with new ends as well and eliminated the plug.
All is good in truck-land now!
