Is it dead?
Old Aug 21, 2006 | 11:14 PM
fooisdone's Avatar
Is it dead?
This is my friend's exhaust housing. Can it be saved?
It is off a Volvo and made by Garrett, that's all I know about it's origins.
The wheels had no sign of rubbing, virtualy no side to side play, with negligible play in and out.
The only other problem compressor side appered to be leaking oil.
It was suggested to me that he could braze it. But will that hold up to the high heat of a suped up gasser?
(It will be going on a '96 ferd escort with a 1.8)
Old Aug 21, 2006 | 11:25 PM
satburn's Avatar
We braze parts together where I work and you're talking about some temperatures really close to the red range on my pyrometer during a truck pull. Not sure about the exhaust temps on your gasser, but if they're anywhere close, I would have concerns about it holding together.
Here's an option as well:
http://www.locknstitch.com/CastIronWelding.htm
Old Aug 22, 2006 | 01:24 AM
Clayten's Avatar
DTR's Toad Wrangler
Use what is knowen as ni rod. It is specifically for cast. You run it off of a DC electric welder. Make small passes not very long have an air hose handy to blow on it and keep it cool or it could crack if it gets to hot and cools to quick. Also peening it is some thing to do between passes.
Old Aug 22, 2006 | 07:19 AM
Mexstan's Avatar
Brazing on parts that get very hot (ie exhaust systems) could result in more cracking in time as the brazing hardens and gets brittle due to the heat and expansion and contraction. Using the correct rod plus peening as already mentioned will be much better. The peening works better if it is started while the weld is still red.
Old Aug 22, 2006 | 07:47 AM
Mcmopar's Avatar
OK, since no one did it I will---Why
Old Aug 22, 2006 | 08:42 AM
Hillbilly_Deluxe's Avatar
My Thought Exzactly, Who Turbo's a Ford Escort?????
Old Aug 22, 2006 | 10:05 AM
fooisdone's Avatar
He's mad that my brick wall on wheels can beat him in the quarter mile.
Old Aug 22, 2006 | 10:12 AM
Mcmopar's Avatar
no sence of humor
Old Aug 22, 2006 | 06:27 PM
fooisdone's Avatar
Thanks for all the good info guys.
That was some good reading in that link satburn.
What is peening and how would I do it?
Old Aug 23, 2006 | 11:39 AM
Clayten's Avatar
DTR's Toad Wrangler
Peening is lite tapping on the weld with a small hammer. Or if you have a air chipper you can use that. This will help relieve the stress that builds in the weld and the parent metal.
Apocalypse
Jul 1, 2008 12:09 PM
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
