Case 480c tractor grid heater/glow plug
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
ya you can get an in line for a radiator hose or go thru a freeze plug and it will be fine. that is all we had in Idaho on our old backhoe. fired up every time (well with the exception of that -40 week straight, nothing wanted to start)
A couple of years ago I did a quick valve job on a Case 188 diesel in a 580B for a buddy of mine, same engine thats in the 480. I would not even dream of putting glow plugs into an engine that was not designed to have them. You have no idea were the water passages are or what glow plug to use and how close to put it to the injector. A disaster in the making to attempt something like that.
Try this site, this is Case's parts catalogs, search for 480 and it should come up.
https://webparts.pvassociates.net/cnh/webparts/main.php
From looking at the parts break down, there looks like there is a screw in plug on the intake centered. Almost ideal for the 12v fuel type cold start aides.
Or you can get one of the plain 12v coil type heaters used in the other Case 480 models.
As far as block heaters go, we have a 1000W can plumbed into our JD410 backhoe. Works great, only needs to be plugged in for 2 hours to heat it up enough to start. The important thing is the plumbing, you have to make sure it will thermosyphin coolant into the block.
I don't think we'll get 40 below out here. So it looks like either idea here will work. Thanks for the info.
No that does not sound reasonable at all. I would have told the seller he did not know what he was talking about right then and there. And probably not have bought the machine from him, but thats just me.
I haven't bought the tractor yet. He's asking $5k plus my trailer, which I valued at $700.00. But the motor was rebuilt and has 40 hours on it since then. It's either that or a Yanmar with 26hp and FEL (the Yanmar looks new).
Thanks for all the info. I'll research the site you provided after I get back.
I thought about that, but I don't want to have to "plug" the motor in for several hours before I use it. At least when I don't plug in my truck, my only issue is no heater for the 1st 15 miles or so haha.
Will a block heater/coolant heater get the motor warm enough to actually start in cold weather (Edgewood)?
Until recently, I thought all diesels had glow plugs/grid heaters.
We have a few of those, Cat's and Deere's. Don't forget about the ones that started on gas and then switched over to diesel.
olddodgetrucks;2649663
ihc td6/9/14/18 start on gas then run on diesel
jd r/80/820/830 gas engine to start diesel
cat old d4/6/8 gas motor to start diesel/coolant ran thru both motors to warm up diesel
Don't forget the Cat d2!
Dangerous Dave
02-07-2008 09:22 PM
