Battery ?
Old Jan 4, 2008 | 10:27 PM
old dog's Avatar
REALLY old dog
Talking Battery ?
Ok I Have A Battery I Pulled Out Of A Car- Took It In The Basement Put It On The Charger- It Started Out Last Night Reading 10v But Battery Is Frozen - Ok Ill See What Happens 24 Hours Later Still Frozen However Reading 12v And Instead Of .3 Amps From Charger Its Taking 2.5 Amps .
Now I Always Thought If A Battery Froze It Was Junk - So What Do I Have ?
Cant Belive Battery Is Still Frozen Basement Is 40 Degrees .+ Its Been On The Charger For More Than 24 Hrs.
Let Me Know What You Think .
Claude
Old Jan 4, 2008 | 11:07 PM
Dean Snow's Avatar
I found this searching
Freezing:
Yes a battery can freeze because part of the electrolyte is water; but a maintained battery will not freeze under normal operating conditions. i.e.: an average deep cycle lead acid battery at a 50% state of charge will freeze at about -24 degrees centigrade and -16 when 75% discharged (which will never happen ...right? ) However, even with this in mind we prefer clients to bury insulated battery enclosures to help protect batteries from extreme temperatures.
I'm guessing that means your battery is junk? I could be wrong
But, i think if a battery freezes its junk.
Old Jan 5, 2008 | 12:20 AM
Bark's Avatar
From past experience, if a battery freezes it will never be very good again dispite charging ect. Seems like it warps the plates etc. Also, I know I dont need to warn you about the rather explosive possibilities of charging a frozen battery. Perhaps you lucked out and it wasnt frozen all the way, just a skim on the top.
Old Jan 5, 2008 | 09:32 AM
Dean Snow's Avatar
I never thought of that. He is lucky it didn't blow up on him seeing that charging a battery like that will build up hydrogen and oxygen in it as the electrons run through the water. And one spark- BOOM!. He must have lucked out and the relief valves weren't frozen. That is if it was a Maintenance free battery.
Old Jan 5, 2008 | 04:11 PM
old dog's Avatar
REALLY old dog
Its Not A Matinence Free- Caps Are Off And A Heater Sitting Along Side(electric)
Old Jan 5, 2008 | 04:17 PM
Raspy's Avatar
Is there any chance that it's not frozen but just low on water and looks like it's frozen when you look into the cells? Hard to figure how it can stay frozen while on the charger, inside and near a heater.
John
Old Jan 5, 2008 | 04:35 PM
old dog's Avatar
REALLY old dog
Just Checked It Again0 Unpluged Charger For Now- Heater Still On- Only 2 Cells Still Look Frozen-
When It Gets Thawed Ill Put Charger Back On It -
*ends &sides Of Battery No Longer Swelled Out Starting To Look Normal Again
Claude
Old Jan 6, 2008 | 09:38 AM
old dog's Avatar
REALLY old dog
Smile
Dont Know But Might Have Gotten Lucky- Checked It Last Night -had Thawed Out - Was Up To 14 V -may Have Caught It In Time To Save It,
Old Jan 6, 2008 | 09:43 AM
Jeff in TD's Avatar
I've had ones that were slushy that survived. Frozen solid might be another story.
They will take a surprisingly long time to thaw out. I think I'd wait until it's thawed before attempting to charge.
Old Jan 6, 2008 | 10:41 AM
Redleg's Avatar
I think it's a matter of the ice pushing the plates or connections around in there. Can't say I'd hook one up in the house though.
Old Jan 6, 2008 | 01:47 PM
old dog's Avatar
REALLY old dog
Show`s Full Charge Now - Took Charger Off And Will Re Check It After While- Its All Thawed Out -might Be Ok
Old Jan 6, 2008 | 06:00 PM
Bark's Avatar
Im impressed. Be interesting to see what a load test does after its all charged.
Rancher99
Apr 18, 2011 09:46 AM
jesussaves
Nov 7, 2010 06:55 AM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
