Air horn help
Old Apr 15, 2006 | 01:54 PM
rico334's Avatar
Air horn help
Anyone who may be running truck air horns, I am needing a little advice. I have a dual horn Grover truck horn (1 is 14", 1 is 19"). I am piecing together items to install this on my Ram and found this compressor/tank on Ebay. Anyone know if this would be a good match for the horns?
I have an 8gal tank already but am short a compressor of some sort to hardwire to this tank, then I ran accross this combo deal and wandering what anyone thinks.
Thanks for any input.
Rick
Air compressor/Tank
I have a large in bed tool box and that is where I have planned on mounting a tank and compressor. They would all be out of the weather and a fair amount of security too. (atleast they would have to work longer to get them.)
Old Apr 15, 2006 | 05:17 PM
chaikwa's Avatar
I think that would be a fine pump if you have room to mount it somewhere. It *may* not keep up with the horns if you use them continuously, but should be fine for 'normal' usage and should have a fairly quick recovery time.
I have a REAL small Thomas 12V pump feeding 2, 30" truck air tanks. It takes about an hour to fill both tanks from 0 psi to 140 psi, but the horn will last longer than I need it to with those 2 tanks. For what it's worth, I have a single, 30" 'Grover Emergency Horn', the same thing that's used on firetrucks. I used to rebuild firetrucks so the horn and a few other things inside the truck cab were used sorta as a 'demonstration' kind of thing.
I wouldn't hesitate on that ebay pump tho.
chaikwa.
Old Apr 16, 2006 | 09:29 AM
Redleg's Avatar
What!? You didn't tell me you had that! I didn't get to play with it! Give those horses (and some neighbors) a little character builder.
Old Apr 16, 2006 | 09:55 AM
Buckshotmckee's Avatar
This is what I'm running and its more then enough. It recharges the tanks within seconds. Mine came as a kit, horms, tank, pump, hose, fittings, etc...
http://cgi.ebay.com/ebaymotors/12-Vo...3540QQtcZphoto
ETurner
Mar 17, 2011 03:00 AM
herb
Jul 18, 2008 08:25 AM
shaft
Mar 21, 2004 05:12 PM
Central Texan
Dec 25, 2003 02:32 AM
bigfoot
Dec 25, 2003 02:30 AM
