3M tape removal
Old Sep 1, 2006 | 09:57 AM
staarma's Avatar
3M tape removal
How is it done or isn't it?
Old Sep 1, 2006 | 01:38 PM
CSAGrey1's Avatar
Go to just about any hardware, grocery, auto parts, Wal Mart etccc. and get yourself a $4 bottle of Goo-Gone. That stuff will take tar off the road if you let it sit long enough. Just spray a little on a dry cloth, hold it on the sticky spot for a minute or two, then whipe the adhesive away. DO NOT SPRAY DIRRECTLY ON YOUR PAINT as this stuff will also remove any wax job you have so try to keep it as local as possible.
Old Sep 1, 2006 | 02:59 PM
zfort001's Avatar
WD-40 spray on and wipe off takes all kinda nasteys off from marker to crayon to tape residue.
Old Sep 1, 2006 | 04:11 PM
staarma's Avatar
I'll try them both. Thanks.
Old Sep 1, 2006 | 05:00 PM
Bill Tomlinson's Avatar
Try a blow dryer to loosen the tape and solvent or goo gone or whatever to get rid of the sticky crap.
If there is just a little, a cleaner wax is pretty safe be cause it won't damage your paint.
I wouldn't use a heat gun because it may lift your paint.
Old Sep 1, 2006 | 05:34 PM
The fine folks who make PB Blaster penetrating oil make a product called DSR. I used it with great success on a large dealer emblem that was held on with what looked to be 3M trim tape.
http://www.pbblaster.com/store/morei...m?Product_ID=6
Old Sep 1, 2006 | 06:02 PM
CSAGrey1's Avatar
Not sure what youre trying to remove but a co-worker just suggested turning one of those cans of air used for cleaning keyboards upside down and freezing it off. Then using hairspray to remove the residuals.
Old Sep 1, 2006 | 06:17 PM
megajoltman's Avatar
WD40 what I use then dish soap if used on paint
pwregan
Sep 5, 2010 02:46 PM
Gypsyman
Dec 31, 2003 06:59 AM
rshelton88
Jan 21, 2003 05:33 PM
rshelton88
Jan 21, 2003 12:06 PM
