Gauge Sensor Dope or Tape Recommendations?
Old Jan 21, 2003 | 11:55 AM
rshelton88's Avatar
Just got a two Westach combo guages (Pyro/Boost and FP/Trans Temp.). To install the gauge sensors what type of thread dope or tape should I use on the threads?<br><br>EGT Sensor?<br>Boost?<br>Fuel Pressure Sensor?<br>Trans Temperature Sensor?<br><br>Thanks in advance for any help!<br><br><br><br>
Old Jan 21, 2003 | 12:29 PM
scottrod's Avatar
Re:Gauge Sensor Dope or Tape Recommendations?
None on the egt probe. Too hot any way<br>Boost and fuel I used a teflon paste that is fuel and steam compatable. Any hardware store will have it.<br>Didn't do my trans. temp yet so I'm not sure there. I'm guessing the same paste will work good. I don't have any leaks so far ;D
Old Jan 21, 2003 | 12:57 PM
TPilaske's Avatar
Don't forget some Anti-Seize on the EGT probe! ;D<br><br>Tony
Old Jan 21, 2003 | 01:47 PM
scottrod's Avatar
Good call Tony 8) Forgot to mention that...<br>
Old Jan 21, 2003 | 03:55 PM
phox_mulder's Avatar
Don't use Teflon Tape on the Fuel Pressure guage.<br><br>It tends to come apart and gum up the works.<br><br>Imagine if you will, little pieces of undissolvable tape getting into the injection pump. :'( <br><br><br>phox
Old Jan 21, 2003 | 05:33 PM
chuck3's Avatar
I did not use anything on mine, no leaks.
steelblitzkrieg
Nov 6, 2007 07:00 PM
Push Rod
May 27, 2003 05:24 PM
rshelton88
Jan 21, 2003 12:06 PM
NWDave
18
Dec 30, 2002 07:56 PM
