30hp john deere dsl project
Old Aug 17, 2005 | 06:48 AM
S_Wilson's Avatar
This motor came out of a air compressor i used on the job, the compressor went down after i had the motor rebuilt so i ended up buying a new compressor for work. So now i got this fresh motor that i'm dying to do something with. I'm thinking of building a mower if i can figure out a pulley sytem for it. I also thought of trying to find a little truck to put it in to see if i could get 50 mph out of it. this thing (3cyl) would run 8-9hrs a day for three days on a 25gal tank. compressors i rented (4cyl) would only run 1 day. I don't know if that idea if pausable or not, what do you guys think?
Old Aug 17, 2005 | 06:59 AM
G1625S's Avatar
Tell 'ya what I'd do is swap it in one of those chevy/geo tracker things. They're small enough where you could get away with running errands w/30 hp. Plus, they have solid axles and old jeeps are just too darn expensive. I'd take a rig like that to get the Sunday paper and coffee--no need to awake the mighty Cummins for such a petty task
g
Old Aug 17, 2005 | 01:43 PM
Jeremy Cusick's Avatar
Build you a garden tractor set up for garden tractor pulling!!!
Check it:
http://www.buttonbuck.com/
Old Aug 17, 2005 | 02:35 PM
gunracer1's Avatar
i have a 4 cylinder diesel from a theremo king that i have been thinking about putting in something small. trackers and side kick have a independent front suspension, so i don't think they will do. but the samurai has solid axles and leaf springs and i belive it would be a much better swap into.
Old Aug 17, 2005 | 03:53 PM
WhiteSport600's Avatar
Ooooh that thermo king diesel is probably a Perkins 90hp or so. That would be perfect in a Geo. I can see it now: Geo tracker, 35" mudders, 9" lift, 90hp Perkins, Ultimate 4-wheelin tuff truck...lol
Old Aug 17, 2005 | 06:35 PM
THen set it up for a turbo... you'll have sometin then!
Old Aug 17, 2005 | 09:39 PM
suzukiZrider's Avatar
id toss it in a geo tracker and possibly put a tiny turbo on it
Old Aug 19, 2005 | 12:37 AM
tempforce's Avatar
perkins diesel
hey my mazda built 2.2L na perkins, is in a ford ranger. big power at 56 hp.
35-38 mpg
just under 200,000 miles
lniemeyer2
May 24, 2007 02:08 PM
doomgaze
Mar 5, 2003 07:08 PM
Jan 4, 2003 10:45 AM
tishmael
Nov 7, 2002 11:38 AM
