Online VE seal kit.
Old Dec 24, 2010 | 12:25 PM
ofcmarc's Avatar
Online VE seal kit.
Anyone got a source for the DGK 121 seal kit online? Can't get ebay here at work and a local source isn't presenting any luck for me......
Oil pan is WAAAAAAY over full, oil pressure is real low and the giant oil slick in the driveway under the draft tube this AM tell me that the front seal gave up the ghost.......
Old Dec 24, 2010 | 03:16 PM
BearKiller's Avatar
Do you have the stock-issue diaphragm lift-pump ??
It could also be the source of all the fuel.
Scratch that; I see you have a piston lift-pump.
As for the seal kit, I got several from a really nice E-Bay vendor in either Georgia or Tennessee; that don't help if you don't have E-Bay access.
Old Dec 24, 2010 | 03:46 PM
BearKiller's Avatar
If time and access to a good machine-shop allow, you can have a snap-ring groove milled in the housing, such that the snap-ring prevents the seal walking out of it's bore.
Old Dec 24, 2010 | 03:53 PM
ofcmarc's Avatar
I can hit the 'Bay tonight after I get home but I was looking for a source I could order from today at work and hopefully get the ball rolling sooner than later....
My plans for the truck aren't gonna require that much seal retention. I'll just locktite the thing in there when I do the job.
Old Dec 25, 2010 | 02:49 PM
ofcmarc's Avatar
Found this place.
http://sto00.mailcar.net/catalog/ind...schm=1&cLink=c
Old Dec 25, 2010 | 05:50 PM
ofcmarc's Avatar
OK, I ordered the kit I found above then afterwords I ran across this:
https://www.dieseltruckresource.com/...ght=front+seal
Am I getting the wrong seal or is that problem old news?
Also, A locktited seal, Will it hold a 2nd gen piston pump with out a regulator?
Old Dec 26, 2010 | 12:55 PM
ofcmarc's Avatar
Ttt
Originally Posted by ofcmarc
ok, i ordered the kit i found above then afterwords i ran across this:
am i getting the wrong seal or is that problem old news?
Also, a locktited seal, will it hold a 2nd gen piston pump with out a regulator?
Old Dec 26, 2010 | 01:00 PM
If it's a real Bosch kit it will be fine.
Old Dec 26, 2010 | 01:01 PM
ofcmarc's Avatar
Cool.
Thanks.
Old Dec 26, 2010 | 01:11 PM
BearKiller's Avatar
If I am seeing right, that kit includes a 366 governor-spring that I have not before seen included before.
If that is indeed the case, then that is the best buy yet.
As for the loc-tited seal holding the increased pump pressure, besides the possibility of actually pushing out the seal, I would also question the possibility of the fuel being pushed out around the shaft.
Old Dec 26, 2010 | 01:17 PM
ofcmarc's Avatar
I saw that too...... I'll let you know when it gets here......
I'm just currious.... Don't plan on doing it anytime soon but finding a 2nd gen LP up here is pretty easy. A low pressure piston pump is a bit rarer. Of course, I do have one of the Sim-flo bypass regulators sitting on my tool box.......
Old Dec 26, 2010 | 01:18 PM
BearKiller's Avatar
I had not seen that particular information before and would also like to know.
The main shaft seal in the kits of un-known heritage that I got from E-Bay appeared identical in every way to the one we removed from the pump in the son's truck.
His old seal was not leaking, but every seal in the pump got replaced; so far, so good.
As soon as clear weather allows, I am resealing the pump in my truck; I am probably losing a quart a day.
Old Dec 26, 2010 | 01:23 PM
BearKiller's Avatar
What I believe would be an advantage to the higher pressure pump, especially in your locale, is that the higher pressure might better push cold sluggish fuel through the system when one is already on the verge of gelling.
Old Dec 26, 2010 | 01:41 PM
ofcmarc's Avatar
I'm already noticing that with the low pressure pump I have on now, the first -40* snap we had this year presented no gelling issues like I assume I would have had with the old diaphragm pump. I didn't even put a new filter on in late September/early October like I usually do in hope that a clean filter will be less likely to plug/gell in the cold.
In years past even with a filter that was nearly new, it would gell at around -35* or so..... been down to -42* already this year without problems...... (at least in the gelling department)......
Old Dec 26, 2010 | 05:02 PM
dieselJon's Avatar
If you read the description at the bottom of the page, it states "New seal kit for most all Bosch VE Injection Pumps with the 20mm front seal. Will repair a lot of Rotary Style Pumps such as the 1988-1993 5.9 Cummins Diesels, VW's, Case Tractors, BMW and more." (Emphasis added)
I just measured the shaft of my extra pump and it is 20mm on my caliper. So yes, it is the right one.
